Old 10-22-2012, 07:03 PM   #1
Squareforceone
Squareforceone's Avatar
Interior paint questions.
I pulled the old rubber mat out of my truck and found the floor boards to quite solid (for an iowa truck lol) However, there are some spots where the paint is bubbling and peeling that just needs sanded and painted. Now ideally id sand everything down to bare metal and por-15 it but cash is super tight so i was thinking of putting down some black rustoleum for now. Would it hold up well? i have a leak in the cab that leaves water on the floor would rustoleum do a very good job at keeping the rust away? Also was wondering how to find out what my interior paint color is called the sticker in the glove box confused me on which code was the interior paint. Sorry for the long winded question thanks guys.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 10-23-2012, 09:38 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Interior paint questions.
rust paint works great on the floor done a few like that
warmer the better,thin coats it will dry quicker
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-23-2012, 09:42 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Pot 15 is great but also getting all the rust out and using a rust converter and then rust oleo on it will do fine. Look at boating shops or body shops for rust converter
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-24-2012, 08:13 AM   #4
dwatts1984
I've used POR 15 also,
http://www.ebay.com/itm/POR-15-Paint...&forceRpt=true
Seems expensive however it works great. Actually does what is says it will.
Ive also used OSPHO in the past. If you take off the majority of the rust with a wire wheel and drill. Then use the OSPHO to convert rust... Then prime and paint should be good. Products like "Rustoleum" don't stop rust. They're just paints. Its the cleaning and converting that helps get rid of the rust and keep it from spreading.
Good luck
dwatts1984 is offline   Reply With Quote
Old 10-25-2012, 07:20 PM   #5
Squareforceone
I cant afford por-15.. i already said that.
Old 10-26-2012, 01:25 AM   #6
xs-style
xs-style's Avatar
they do make rustoleum thats specific for treating rust spots. you could go that way. or do what i did under my sound deadner and use the ruberized undercoat. that was only like 8 bucks a can. youd maybe have 2 cans on the floor if you laid it on thick.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
