Ridin' Dirty
Anybody know the GVW rating of our crewcab trucks?
Anybody know the GVW rating of our trucks? More specifically, I'd like to know the GVW of my 1990 V3500 crewcab single wheel 1ton 4x4.
My glovebox has a sticker that says I can put a 2495 lb slide in camper on it, but I'd like to know what my total maximum weight of my truck is allowed (or designed) to be.
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
Re: Anybody know the GVW rating of our crewcab trucks?
it is my understanding that it really depends on the year as some one tons are 9g up to 12 or 13g but would be nice to know the real numbers
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Ridin' Dirty
sorry, whats the g stand for?
I am pretty sure its 9,000 pounds. My 1990 V3500 dually is 12,000 pounds. Its 4500 for the front axle and 7500 for the rear axle.
The actual gvw of your truck is 10,000 lbs, not 12,000 lbs. It may seem counter-intuitive, but you don't simply add the two numbers. The single axle models are either 9200 or 8600. See the attached pdf for a copy of the gvw from GM's literature.
Ridin' Dirty
Kinda like how the dually tire weight ratings work. The weight limit doesn't double even though you've doubled your tires.. I always thought that was strange.
Do you have a placard on your driver's door? It should say so there.
GVWR fascinates me ( mine is only 4900). But i think engine, trans and rear gear ratio also determine it. Not just chassis components. Along with the pdf j.b. provided, i have seen gvwr's for 1 tons to be 8600, 9000, 9200, 9600, and 10000. |
#8 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#9 | |
Ridin' Dirty
sorry that g was ment to be a k. way to sleep deprived. now you mean to tell me that my 3/4 ton that is rated 8600 could be the same as a one ton? i know mine is a reg cab but still dont seem right to me. now i wonder what my one ton really is
9200 lbs.
I pulled up the free info packet from the GM Heritage Center archives. You can find them here: http://www.gmheritagecenter.com/gm-h...tion-kits.html I chose the info packet for an 87 V3500, because if you check the 1990 model year stuff you get GMT400 info. At any rate, 9200 lbs for single rear wheel; 10,000 for a dually, unless it changed from '87 to '90. By the way, earlier in the info packet it also specifically showed "payload" for the various models; payload for the V3500 crew cabs was 3771 lbs (page 33). K ![]()
Ridin' Dirty
^^That's what I'm talkin about!!^^ Thanks!
#13 |
Mine scales in at 6500 with one half full fuel tank and me in it.
#14 | |
K
#15 | ||
Charlie Daniels w/ a Tq Wrench
The reason for the dual tire rating being lower per tire is because of a few situations that can affect the load on the tires. One being the crown of the road, due to the uneven shape of the road, the dual tires are not going to be evenly loaded, generally the inner tire takes more of the load in this situation. Also, if you have unevenly worn tires in the back, say one 1/2 tread tire, and one nearly new, the newer tire has a larger overall diameter, although a small difference, it still hits the ground before the other tire, therefore taking more of the load. A difference in tire pressure, or even tire temperature will have the same effect. Because of this the tire companies apply a 10% or so lower rating to tires used in dual applications to account for these variations.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#16 | |
Ridin' Dirty
