Old 10-22-2012, 09:42 PM   #1
sigshooter
sigshooter's Avatar
Arm rest mounting fix, gotta see this
The arm rest mounting is a problem for these trucks, the little spring loaded nuts that fit in the doors seem to get loose and give away. I have found these on 1964 model trucks and vans only, they are a metal bracket with nuts welded to them. They simply go on the inside of the door panel and the arm rest bolts to the outside of the door panel, making a very solid mount.
I installed them on my 65 tonight where it never had armrests using an old door panel i had to mark the hole locations
This might help some out that have doors with the square holes pulled thru
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 10-22-2012, 09:45 PM   #2
sigshooter
sigshooter's Avatar
Re: Arm rest mounting fix, gotta see this
more photos
1966 Short stepside
1964 long bed
Old 10-22-2012, 09:57 PM   #3
nachodog2
Hell yeah!!!
nachodog2's Avatar
Not bad!
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
