It's alsways something.....
![]() Join Date: Nov 2008
Tie rod end help for drop spindle installation
I installed a set of drop spindles on my 71 2wd Blazer- These use the 73 & Up larger taper outer tie rod ends. I have done several of these in the past and rounded up a drag link setup from a 73& up donor. The junkyards here are now not quite as numerous-
so what's the alternative? Is there a tie rod sleeve that replaces the 71 model and allows the 73 & up outer? Part number and supplier if anyone knows- if not, I guess I'll make the junkyard run- Thanks
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Restoration Virgin!
Re: Tie rod end help for drop spindle installation
Chuck....have you looked on this awesome post by lolife99?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Those are great- I was hoping someone who had bought the adapter sleeves could post a part number and price
67-72 parts collector,…
![]() Join Date: Nov 2002
71-72 tie rods are the same diameter as 73-87 (11/16")
You can use a 71-72 centerlink with a 71-72 inner tie rod connected to a 73-87 outer tie rod. I would think a 73-87 centerlink would be easier to find. But your original 71 2wd blazer center link will work just fine.
The adapter sleeve is for the smaller tie rod 67-70 centerlink.
These tie rods are 5/8" diameter. Plus they are the wrong thread direction. To make this work: 1) 67-70 centerlink 2) 67-70 outer tie rod in the inner location 3) adapter sleeve 4) connected to a 73-87 outer.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-01-2014 at 02:05 PM. |
Thanks Keith. So, I just need to order a set of 73-87 outer tie rod ends and I am in business?
Yes.
