Old 10-23-2012, 12:47 PM   #1
62'comingthru089
How do you install Door and window regulators for a 62 Chevy ?
Hey I was just seeing if anyone out there knows how to install door regulators without having to break the glass? The reason I say this is I've looked at what I have to do and it seems the only way to get them in is breaking the glass is this true or is there a way to take the glass out before u install the regulators?
62'comingthru089 is offline   Reply With Quote
Old 10-23-2012, 01:20 PM   #2
1963c-10
1963c-10's Avatar
Re: How do you install Door and window regulators for a 62 Chevy ?
Glass will come out through the top. I haven't gotten to this stage yet, but have removed one in a parts truck. The window fuzzies will come out, door panel off and then it'll come out through the top opening.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-23-2012, 10:18 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
The following explains all the repair and adjustment steps pertaining to the doors and windows:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-24-2012, 04:32 PM   #4
forestb
forestb's Avatar
just keeping track of the thread
forestb is offline   Reply With Quote
Old 10-25-2012, 01:13 PM   #5
61K10
61K10's Avatar
my doors don't have the outer door weather stripping? it's a 61. was this on all years of the early door style?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-25-2012, 01:16 PM   #6
1963c-10
1963c-10's Avatar
The pics that Mark posted were from the 63 Truck shop manual
Old 10-25-2012, 01:28 PM   #7
61K10
61K10's Avatar
thanks for the reply. maybe 63 only?
1961 chevy K10
Old 10-25-2012, 02:22 PM   #8
1963c-10
1963c-10's Avatar
I have a 61 door thats going on my 63. Let me check tomorrow and I can tell you if it has the weatherstrip on it. My 63 does have them.
Old 10-25-2012, 02:42 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Actually the information from the service manual is from the 1960 Chevy Truck Shop Manual.
Old 10-25-2012, 02:54 PM   #10
1963c-10
1963c-10's Avatar
Ahh...my mistake. They used the same pics in the 63 book. 61K10, maybe the PO took them out?
Old 10-26-2012, 02:07 PM   #11
61K10
61K10's Avatar
1963c-10-----i have 4 different doors, 2 org. and 2 donor. one had a no metal window frame and none had this weather stripping. the one without the metal frame was repainted though. is this the same as the cab weather/s. if so is the kits long enough to add this to the door? is it to keep water out? has anybody installed it?
1961 chevy K10
Old 10-26-2012, 02:59 PM   #12
1963c-10
1963c-10's Avatar
The glass w/the metal frame requires a different weather seal kit than the non-framed glass does. Doesn't matter which style you use (metal framed/non-metal framed), either will work in any 60-63 door. Just be sure to get the proper kit for which glass you use. I believe the only purpose of the weatherstrip behind the door panel was just to seal out any drafts. I cant imagine any water coming in or out the way the door is designed. Again..i think its just to keep drafts out.
Old 10-27-2012, 06:28 AM   #13
dthela
dthela's Avatar
At the bottom of the window are 3 screws holding bottom to regulator. Hold glass at height to reach these, take them out and slide regulator side to side to get rollers from track.
dthela is offline   Reply With Quote
Old 10-27-2012, 12:15 PM   #14
61K10
61K10's Avatar
doesn't the regular w/s seal the door? I understand about the window difference.
back to the window removal--the info Markeb01 posted should walk you through it. post back up if having problems.------good luck!
1961 chevy K10
Old 10-27-2012, 10:28 PM   #15
62'comingthru089
Hey thanks everyone for the information. I'm going to knock it out tomorrow hopefully. Ill post back if I ran into any problems. Thanks again
Old 11-15-2013, 02:41 PM   #16
1963chev
1963chev's Avatar
Just Wanted To Say Thanks For The Shop Manual Post as I Am Finally To Window Installation.
1963chev is offline   Reply With Quote
Old 11-15-2013, 02:53 PM   #17
1963c-10
1963c-10's Avatar
Another good pic
Old 11-16-2013, 12:21 PM   #18
1963chev
1963chev's Avatar
Thank You Once Again. Do You Happen To Know The Order I Put the parts Back In? I was Going To Start with The Ventilator (Windwing) First But After Reading Your Posts It Seems The Window Goes in At The Same Time As the Ventilator. I Have A Spare Door And Parts I Have Been Practicing on But It Seems Like I Am Going To Scratch The New Paint!
Old 11-16-2013, 12:47 PM   #19
LVPhotos
LVPhotos's Avatar
I had my vents in first turned them sideways then put glass in. I had the rollers up far enough to set glass on temporary the reposion the vent. Put glass in channel then work it onto the rollers. Tape will help from scratches. You might want to spread door opening to get vent in without scratches.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
