Old 10-23-2012, 06:47 PM   #1
72 Super
72 Super's Avatar
72 1/2 4x4 ton rear LIFT blocks factory??
Does a 1972 1/2 ton 4x4 have rear lift blocks from the factory? Mine has 2 inch blocks although I know they aren't original. I was going to remove them, but have been told I need some sort of block in there.Is this correct?
thank in advance,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 10-23-2012, 06:56 PM   #2
69GWC
Re: 72 1/2 4x4 ton rear LIFT blocks factory??
I know my 69 did not come that way, But when I bought my 2.5" lift I put in new front springs and the 2" blocks in the back.
Kinda sounds like you have 2"' lift blocks, does it set level?
69GWC is offline   Reply With Quote
Old 10-23-2012, 07:23 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 has a block above the mounting pad and at the bottom of the spring pack, right where a lift block would go. It's about 1/2" thick. That may be what you've been told you need.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-23-2012, 08:38 PM   #4
72 Super
72 Super's Avatar
It sits about 2 inches higher in the rear. I will look into it and see what I can find out about a block or pad of some kind..
Old 10-28-2012, 09:48 PM   #5
72longbed
72longbed's Avatar
Those blocks would have been put in there anytime over the last 40 years by an owner ... but Chevrolet never used blocks in 67-72 leaf spring trucks from the factory. Chevy/GMC dealers would sell you a taller spring pack 'back in the day'. I've seen 67-72's with as many as 11 leaves.
Ford and Dodge have done it (blocks) from the factory over the years.
I've worked on Ford trucks that had 3" blocks fresh off the assembly line.
72
72longbed is offline   Reply With Quote
Old 10-30-2012, 01:44 PM   #6
72 Super
72 Super's Avatar
Yes I know the blocks were added at some point. I had a friend that thought I may need some sort of thin block or pad between the spring and rear housing. I have confirmed I don't by several members on here. I just need to remove the blocks along with shorter U bolts.
Thanks,
Ray
Old 10-30-2012, 01:45 PM   #7
72 Super
72 Super's Avatar
here are the blocks I will be removing.
Old 10-30-2012, 02:18 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Maybe the OEM 1/2" blocks I mentioned above were only used on K20s, and not on K10s.
- Mike -
RIP El Jay
Old 10-30-2012, 05:00 PM   #9
72 Super
72 Super's Avatar
[QUOTE=Stocker;5676430]Maybe the OEM 1/2" blocks I mentioned above were only used on K20s, and not on K10s.[/QUOTE
I believe that is correct. I also talked with someone with a 1 ton and they have a block/pad of some kind too. Slowly leaning a few things here
Old 10-30-2012, 06:05 PM   #10
72longbed
72longbed's Avatar
All aftermarket. Show me the factory 'build spec.s' that picture these blocks.
I have never seen them in any factory buld diagrams.
72
Old 10-30-2012, 08:18 PM   #11
GMC K2500s with the Dana 60 came stock with blocks about 3/4-1",I'm estimating. I have never had a Chevy K/20 with HO52 have a block of any sort.
Old 11-05-2012, 11:20 PM   #12
1972RedNeck
1972RedNeck's Avatar
The early highboy's had 3 1/2" blocks and the later ones had 4" blocks.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-06-2012, 12:13 AM   #13
kris's66lwb
resident wrencher
My 66 k20 with ho52 had 4 inch blocks factory
kris's66lwb is offline   Reply With Quote
Old 11-06-2012, 07:46 AM   #14
Yep,the pre-67s were also Highboys,just like the pre-78 Ferds. It's all about the divorced transfer case arrangement. Except '60s Dodges,they sat lower than Ferd and GMs.
Old 11-11-2012, 05:03 PM   #15
72 Super
72 Super's Avatar
I removed the 2 inch lift blocks from my truck. It now sits factory and looks better IMO. I believe the previous owner used it for towing. I just didn't like the rear sitting up higher than the front.
I cleaned and painted the U bolt plates/retainers while it was apart.
I like to thank Rob (BLAZERMAN) and Bill Athey for the information and answering all my questions and I got the new U bolts from Bill Athey (pickupman)
Thanks,
Ray
Old 11-11-2012, 05:10 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Glad it worked out and you got the look you wanted. If the truck will ever get off-road, you may want to trim the excess length off the u-bolts. It's too easy to snag them on something and bend 'em over.
- Mike -
RIP El Jay
Old 11-11-2012, 09:47 PM   #17
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Glad you got her back together Ray...now quit teasing and show some pics of that Beauty!!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-11-2012, 09:59 PM   #18
72 Super
72 Super's Avatar
I like it a lot better this way. I doubt it will ever see any serious off road use, but I may trim them at some point just incase.
Old 11-11-2012, 10:05 PM   #19
72 Super
72 Super's Avatar
Here you go!
Here are a before and after picture. Not the best picture in my driveway. I will take some better ones and I want to do a write up for the board, just haven't got there yet.
