Old 10-23-2012, 08:55 PM   #1
72 Super
72 Super's Avatar
1972 chevy truck small block valve cover differences
Are there two versions of the small block 350 valve covers for our trucks? The reason I am asking is on the trucks without the oil fill tube, there isn't an opening on the rear of the drivers side valve cover. The trucks I have seen without the tube have three openings drivers side PVC valve- passenger side oil fill cap, air cleaner elbow.
So should the trucks with the long oil fill tube have two openings on each cover? I know the covers can't be switched because of the factory wire clips on the one.
thanks,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 10-23-2012, 11:46 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: 1972 chevy truck small block valve cover differences
the covers Left or right are interchangeable. One cover with 2 holes, one with one small breather hole. With the filler neck the 2 holer goes on the LH side or it goes on the RH side if you don't get the fill tube. The single hole cover is then on the opposite side.
I haven't seen spark plug mounts on the valve covers for 72 and older. Rams horn manifolds have wires that run down the back side of the heads and under the manifolds. There is no reason for wire keepers on the valve covers. They must be 73+ covers.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 10-24-2012, 10:55 AM   #3
72 Super
72 Super's Avatar
Da burb, that. Is what I had thought, but the clips I am referring to hold the wires running along the intake. I have seen the clips on the single hole cover and on the cover with the two openings. These were on different trucks though and only one cover has the two clips.
Old 10-24-2012, 02:18 PM   #4
Ozark Tim
Ozark Tim's Avatar
Those are for routing of the temp sensor wire and a/c solenoid wire (if 1/2 ton with a/c) and would be the driver side valve cover.
Every 72 V-8 I have ever seen have two holes on each valve cover with the crancase vent going to the smaller and rubber plug oil fill caps on the larger or the driver side rear gets the extension with power brakes and a/c.
Here are the best pics I have.
71 307 without extension (no p/b)
72 with all (a/c, p/b) etc
And yes, plug wires routed from distributor to tower on rear inboard v/c bolt, down to a bracket mounted to the rear of the block just behing head and then routed along block/oil pan and up between block and motor mount for front 2 wires
Ozark Tim is offline   Reply With Quote
Old 10-24-2012, 02:21 PM   #5
Ozark Tim
Ozark Tim's Avatar
Wait a minute, that center pic is wrong! Try this again.
Maybe this one is better??
Old 10-27-2012, 10:03 PM   #6
72 Super
72 Super's Avatar
Ozark Tim,
thanks for the infomation and pictures. There have been a couple sets here lately on the board for sale. They all were the 3 opening type. I would of thought like Da burb mentioned that they were interchangeable from side to side if it wasn't for the wire routing clips not being located on the same cover on the couple sets I have seen for sale. One set the 2 clips were on the 1 opening cover and the other had the 2 clips on the 2 opening cover.
Here is a picture from Ebay, are these correct 72 truck covers?
Thanks,
Ray
Old 10-30-2012, 01:51 PM   #7
72 Super
72 Super's Avatar
Anyone have an a picture of their valve covers on a 72 4x4 non-AC truck?
thanks,
Ray
