Old 10-23-2012, 09:04 PM   #1
T2vigil
T2vigil's Avatar
Soft or Hard?
Now that I have your attention. I have a modified 250. Flat top pistons, decked block .025 and a Comp Cam. It is ported to match the gaskets. The HEI I have is bone stock from the junk yard. I have been told I need a Soft Vacuum Advance. How does one tell it they have a Soft or Hard advance? Or is the best way to go is an adjustable advance?
Thanks for any info.
T2vigil is offline   Reply With Quote
Old 10-24-2012, 09:21 AM   #2
64fleetside
Re: Soft or Hard?
I always use a mid-70s big block chevy vacuum advance can-it limits the advance-it has less travel. It's a pretty obvious difference once you have the two side by side. Not sure if they fit the six HEI but I think they might be the same.
64fleetside is offline   Reply With Quote
Old 10-24-2012, 11:35 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
Re: Soft or Hard?
Use a G.M. HEI with a soft spring vacuum advance can PN (1973691)
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-24-2012, 06:37 PM   #4
T2vigil
T2vigil's Avatar
Re: Soft or Hard?
Thank you Rich. The local O'Rileys had one in stock and there is a large difference in the way they react. Now for one more question. The distributer has about a .25 inches of vertical play. PO installed so I have no history. What is the end play supposed to be and Where can one get the required shims? OK that is two questions.
Old 10-24-2012, 07:22 PM   #5
tincan1966
tincan1966's Avatar
Re: Soft or Hard?
Having the distributor blueprinted and the proper centrifical(sp?) advance setup is equally important.
tincan1966 is offline   Reply With Quote
Old 10-24-2012, 11:59 PM   #6
Rich 5150 69
Re: Soft or Hard?
The end play should be 0.010 ..that will only allow a one degree variation. any tighter will result in excessive wear. Most speed shops will carry them or summit / Jegs
Old 10-25-2012, 11:37 AM   #7
T2vigil
T2vigil's Avatar
Re: Soft or Hard?
Rich, Thanks for the link. I am headed to the pick - n- Pull this afternoon to see about another HEI distributer and take the best parts to make one good one. Again thanks for the for the help.
