Looking for a Aluminum valve cover
I have a 250 6 cylinder and looking for a cover with pvc hookup,looking at the offi but how hard is it to drill into the finned top or can you drill on the side,will it suck oil?other brands?My options?
Re: Looking for a Aluminum valve cover
wow,dont all reply at once!!!
call this guy, he might steer you in the right direction
http://stoveboltengineco.com/ |
It's Better With Nitro
It's not difficult. I machined my friend's Offy valve cover for his PCV valve.
Yeah, was going to say that any machine shop should be able to handle it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I used an Offy on one of my sixes. Didn't have a baffle so I used a breather like this to hook the pcv to. It worked like a baffle. Used a clear vac hose on it to watch for any oil getting by. Never saw any.
http://www.jegs.com/i/Trans-Dapt/969/4999/10002/-1 And I used a breather like this near the back on the passenger side to let air in. ![]() |
It's easier to use a baffled grommet like these...
http://www.speedwaymotors.com/PCV-Gr...Caps,7332.html http://www.streetsideauto.com/p/moro...FcaDQgodGywAgA This is what I used for my friend's Offy VC in the photo. ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 10-26-2012 at 02:45 PM. |
