10-23-2012, 09:31 PM | #1 |
63' Dome Light and Gas Tank questions
We made a lot of progress on the 63' this summer. It is now a drivable truck and my son and I are loving it. Question about the dome light. How does it turn on? There are no door pins to trigger it. Does it turn on by turning the headlight switch? Also regarding the fuel tank, It has been repainted and has some kind of padding under the tie down straps. Do the straps act as a ground to the mounts? If so then the paint and/or padding could be preventing a solid ground? When I turn on the key, the guage goes off the right end past the "F" and does not giv an accurate reading.
10-23-2012, 09:46 PM | #2 |
Enjoy your truck
Re: 63' Dome Light and Gas Tank questions
The dome light is activated by the headlight switch only.
As for the ground on the gas tank, mine had a seperate wire that ran from the sending unit to a screw above the tank on the rear cab wall. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
10-23-2012, 09:56 PM | #3 |
Senior Enthusiast
The dome light is designed to have power at the light all the time. Illumination is controlled by the ground side of the circuit. The headlight switch has a tab on the frame which is engaged at the left end (counterclockwise rotation) of the knob.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
10-23-2012, 10:17 PM | #4 |
When did they change the Ohm level in the fuel tank sending unit? We had a second tank come with the truck that we switched out because the original tank leaked...Not sure of the year of the replacement tank but it was a direct swap...sender unit worked fine until after the switch...ground tab to the cab is installed, contacts are free of paint.
10-24-2012, 04:13 PM | #5 |
Enjoy your truck
I am not 100% sure but I believe '60-'63 were 30 ohm and '64-'66 were 90 ohm.
Greg.
10-27-2012, 02:58 AM | #6 | |
10-27-2012, 04:05 AM | #7 |
0-30 Ohms most pre-1965 GM cars and trucks. 0-90 Ohms most GM cars and trucks 1965-up. Most aftermarket stuff is 0-90 Ohms. Also check and recheck all grounds. Lose wires and grounds are the main causes of the fuel guage problem. I have had floats go bad by sinking(empty reading) and just worn out on the float parts themselves.
10-27-2012, 04:09 AM | #8 | |
**If resistance is just enough too great(90- vs 30-ohms is too great enough), far too little current flows thru gauge and sender, and it does not pull the needle off "F" at all. There is a way to splice a resistor into sending unit wire and on to a solid ground (in parallel with sender's resistance) which would decrease total resistance to 30 ohms. If you wanna know the value of such a resistor and how to wire it into system & where to buy it, contact me & I'll go thru it w/you. But you'd need to know the resis of your sender--need to take it out & check w/ohmmeter--lotsa trouble, but it'll allow you to use whatever sender you have. Last edited by luvbowties; 10-27-2012 at 04:21 AM. |
10-27-2012, 06:16 AM | #9 |
run a ground from tank to frame. ground is wired to bolt holding sending unit in but you can use a screw in edge of flange. no ground = full guage
10-27-2012, 06:18 AM | #10 |
I bought a switch and installed in dash. Glued old knob onto shaft to match ( you can use a wiper switch etc.)
10-27-2012, 10:03 AM | #11 |
I think I still have the old sending unit which I think used to work just fine. My son tried to get started on the swap without me and in an attempt to loosen the threaded fuel line connection twisted the solid fuel line like a piece of licorice...
10-27-2012, 11:29 AM | #12 | |
The 90's are most popular and I'd guess 270-ohm's are used quite a lot too. For it, you'll need to use a 34-ohm, which may be hard to find. Techie at R-Shack should be able to help you come up with a combo of 2 or 3 resistors to get pretty close. He should be able to show you how to wire them to get what you want--series(end-to-end), or parallel(side-by-side: with a pair of their leads together to form one lead, and other pair together for 2nd lead), etc. BTW: resistors look like these in picture "IMG 5660b.jpg". **Be sure your sender IS WORKING. Put one end of ohmmeter on wire lead that goes to gauge. Other end goes on 'far' end of the resistor in the sender(looks different from these in the pic). Move float from one extreme to other, and it should move meter from close to 'zero' up to around '30' or '90' or '270'. Last edited by luvbowties; 10-27-2012 at 11:36 AM. Reason: spelling...grammar...again, spell |
10-27-2012, 06:26 PM | #13 |
I really appreciate the help but I need it dumbed down a bit...My old 30 OHM sending unit worked but is damaged..my new one does not and I believe it is a 90 OHM unit...all wires are in good order. Can I get one of those items pictured above and just splice it in between the tank and lead wire? If I understand right I need to reduce the resistance from 90 to 30 so I need a 60...What exactly do I ask the guy at Radio Shack for?
10-27-2012, 08:00 PM | #14 | |
Should you wish to see the math and electronic interrelationships that make these 2 resistors combine to make an "equivalent resistance" of 30-ohms, we'll do that in another discussion. But we don't really need to go thru that. Just try & trust me--it works. Last edited by luvbowties; 10-27-2012 at 08:02 PM. Reason: spell |
10-27-2012, 09:07 PM | #15 |
Just got back from Radio Shack and brought this thread with me for the guy to read so we were on the same page...fortunately I had an employee who also knew about this stuff and hooked me up. I will let you guys know how it turned out....LUVBOWTIES, thanks for your help..
