Old 10-23-2012, 10:32 PM   #1
nachodog2
Hell yeah!!!
nachodog2's Avatar
picture request: raised bed floors
I currently have a homebuilt cover on my truck but want to build a raised floor so that i can actually use it to haul stuff around. the cover i use sits stationary in the rear, only the front lifts up. it was made this way because i was going to eventually going to make my tailgate operational., i removed the chains so it makes it difficult to use. the cover would be perfect for a chained tailgate and that is why i want to lose it. So, i would like to see finished pictures of raised floors as inspiration.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 10-24-2012, 09:45 AM   #2
kieth
kieth's Avatar
Re: picture request: raised bed floors
Here is a option for you, I had the same problem because I have chains, they are a pain so I bought this cover and made it so it raises from the rear, that way I can fuel my truck without lowering the tailgate. Kieth
http://kieth.smugmug.com/Trucks/66-G...6670&k=vfHng9N
kieth is offline   Reply With Quote
Old 10-24-2012, 04:40 PM   #3
thekid54
Sorry to go off topic, but Kieth, what color did you use on your truck? I really like that green.
thekid54 is offline   Reply With Quote
Old 10-24-2012, 06:57 PM   #4
jimmydean
jimmydean's Avatar
Delmo's '65 has by far my favorite bed floor. I don't have pics at the ready, but find his pick'em up truck thread. Original wood.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-24-2012, 07:17 PM   #5
Turkey
Turkey's Avatar
I don't have a picture, just wanted to say killer ride dude.
Turkey is offline   Reply With Quote
Old 10-25-2012, 12:34 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine is "semi" raised, it sits differently than a stock floor because of the tubs, fuel cell, and the thickness of the "wood" Its in 3 sections, the front is 1 piece, with the rear split into a battery compartment and a fuel door. This is with the rear sections out when I was painting some of the "frame" parts. its modified bed rails and structural 1/2 sq tube.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-25-2012, 05:18 PM   #7
kieth
kieth's Avatar
its a stock light green for a 66 gmc, but we tried to make it a little better, when they mixed the base coat it was supposed to have white in the formula we substituted metalic silver, where it called for solid yellow we used transparent yellow, we then did the sealer primer coat in white so the green let it shine through , it took a lot more base coats, but we like the results. We used ppg omni and a final 2 coats of polyurethane clear. never even buffed it out........Kieth
