10-23-2012, 11:48 PM | #1 |
NEED TRACTION, 15x12 7BS???? 600hp+ need help!!!
Hey guys some of you may know i finished up my turbo motor in my 68 STEPSIDE and i am desparate for traction lol...
I am wanting to run as wide as possible wheel/tire combo without sticking outside the wheel wells like crazy lol... I dont care about cutting box and making tubs Truck is running 76 5x5 pattern chevy front end and rear end (with custom trailing arms).... I think the axle is a bit wider than the 67-72, not sure tho... This truck will see the track maybee twice a year.... Thinking of running: 15x12 wheel with 7" BS Offset +6.00mm on the rear.... MCKEY THOMPSON 31X16.50-15LT ET STREET OR 31X16.00R15LT SPORTSMAN 15x8 4.5" BS on the front with MCKEY THOMPSON 26X10.00R15LT SPORTSMAN ANY ADVICE, SUGGESTIONS, PICTURES AND SPECS OF YOUR SETUP.... its all welcome! Thanks! |
10-24-2012, 12:02 AM | #2 |
motor exploder
Re: NEED TRACTION, 15x12 7BS???? 600hp+ need help!!!
12" wide on a stepper ain't happenin' without some cutting. I have 18x12's on mine with 7" bs and had to cut out the fender lip and the inside of the bed. I'm running a stock width '69 12 bolt which is narrower than the '71-up rears, but that doesn't change the fact that these steppers don't have a whole heck of a lot of room in the wheelwell to tuck a 12" wide wheel. I gave myself a little wiggle room with the tubs in case I wanted to run a wider wheel or narrow my rearend later on.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 10-24-2012 at 12:10 AM. |
10-24-2012, 12:19 AM | #3 | |
I really want to make sure im not sticking outside the wheel well alot or hitting it.... so backspacing is my biggest concern cuz there is alot of room till i get to the frame Thanks for the pictures and info! Your setup fits nice! |
10-24-2012, 12:33 AM | #4 |
motor exploder
I believe it's like 3/4" on each side, but I'm not positive. I also don't know if the 71/72 rears are the same as the 73-87's, so that is something else to consider. Searching this forum will get you a solid answer. I just broke out the 'ole tape measure and did a little figuring to find what I needed to do. I do know that 7" won't be enough b.s. with the rear you're running. Cutting my fender lip out gave me a 1/2" and would have rubbed/cut my tires had I not cut it out. I wanted my tires sitting almost flush with the rear fenders, not sunk in too far and definitely not sticking out.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-24-2012, 12:43 AM | #5 | |
IDK how much backspacing they can put into wheels but it looks like I might be buyng a set of drag radals to fit my current wheels for now... Then buy a 9" and cutting it down and buildng a 4 link... didnt plan on this for a while though lol, prolly try to get it done this winter... |
10-24-2012, 08:31 PM | #6 |
I didn't have to cut anything to run a 12'' wide wheel on mine. Not saying you want have to guess i was lucky.
15x12 wheel with 7'' backspacing and 325 50 15 drag radials
Brandon Street Car Mafia Last edited by limitedstreetoutlaw; 10-24-2012 at 08:39 PM. |
10-24-2012, 08:37 PM | #7 |
motor exploder
Hopefully 1BADLS1tuner will luck out like you did. There was no way mine was going to fit with the same setup. I couldn't even set my bed down on the frame with the wheels on. I'm running a 335/30/18, which is around 13.5" total width with the tire inflated on the wheel. Got any close up pics of your setup?
10-24-2012, 09:01 PM | #8 |
After reading back on this thread i should have said mine has been mini tubbed but the outer lip hasn't been cut.
I think i have some pics some were on a disc lol have to look
Brandon Street Car Mafia Last edited by limitedstreetoutlaw; 10-24-2012 at 09:23 PM. |
10-24-2012, 09:05 PM | #9 |
motor exploder
Okay, that makes me feel a little better! I was wondering how there could be that much of a difference in two similiar year models and you didn't have to cut the bed
10-24-2012, 09:20 PM | #10 |
Yea i'm bad about reading bits and pieces of a post and then respond and not read back what i typed and sound like a moron. LOL
Brandon Street Car Mafia |
10-25-2012, 12:30 AM | #11 |
motor exploder
Man, that looks MEAN!!! what drop are you running in back? I just mocked mine all up this afternoon before I take it to paint and I need to bring mine down a couple more inches at each end so it sits more like what you have going on. I'm currently just using a 6" drop spring in the back with 2.5" spindles and 2" spring in front.
10-25-2012, 02:09 AM | #12 | |
Love the stance of the truck! What year reared are you running? I'm assuming its the narrow reared..... Also what is the suspension setup? Posted via Mobile Device |
10-25-2012, 02:53 AM | #13 |
I would get the ET Street Radials like these:http://www.summitracing.com/parts/MTT-3757R/
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
10-25-2012, 11:41 AM | #14 |
Yeah baby!
I run 12 x 15 on a '68 stepside. I have mini tubs but the big change I made was to widen the bed.
You think that will look strange? Put a straight edge on the truck door and you will see that the rear fender sits in an inch and a quarter. I widened the bed that amount each side, gaining two and a half inches. I reworked the rear corner so that it takes a standard tailgate. The truck looks great, "tougher" than standard and avoids that overtubbed look than some pro streeters have. I have no pics at present but can get some.
11.37 @116 |
10-25-2012, 08:01 PM | #15 |
[QUOTE=BossHogg69;5666435]Man, that looks MEAN!!! what drop are you running in back? I just mocked mine all up this afternoon before I take it to paint and I need to bring mine down a couple more inches at each end so it sits more like what you have going on. I'm currently just using a 6" drop spring in the back with 2.5" spindles and 2" spring in front.[/QUOTE
Thanks man When this pic was took it had 5'' drop springs in the rear with close too a 2 '' block under the rear. Since then the blocks have been removed. And in the front it's the same as what you have 2 1/2'' and 2''.
10-25-2012, 08:08 PM | #16 | |
As for the suspension set up all stock other than drag shocks on all four corners. hopfully gonna change that over winter with coil overs on rear.
11-21-2012, 05:49 AM | #17 | |
i am running 12" wide with hoosier 29x15.5 but now that i have seen the pic of your rear end i am more confident about what tire to run on my other wheels for the drags. |
11-21-2012, 02:11 PM | #18 |
Will do 69vetteside. Thanks
