BlahBlahBlah
Rhino type liner question
Does this stuff have to be sprayed on metal, or can it be sprayed over another type of coating?
When I get far enough along on my panel (hah) I plan on putting down Lizard Skin heat and sound deadener. I was wondering if they can spray Rhino over that? Part of my future plans for my panel is to be my ride down to Speed Week at the Bonneville Salt Flats, and that salt gets every where. So I'm kicking around the idea of no carpet or mats. Easy clean up!
Re: Rhino type liner question
I just had my wifes blazer top sprayed with Al's Liner which is just like Rhino Lining. It worked great. I'm not sure if this helps in your aplication or not.
Collector of Projects
Lizard skin can be painted over so as long as it had bonded to the metal I dont think there would be a problem.... But I would check with both Lizard Skin and Rhino or Line-X as to chemical campatability.... The Rhino is a two part system that goes on hot and could react negatively....
i had herculiner on my inner bed sides... Ill never use that crap again, im now starting to see primer through the bed liner and it hasnt even that long ago that i did it..
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
