Active Member
![]() Join Date: Jan 2011
Need quick Rear end help!!
If I can get some quick help please. I'm at a pick a part right now and I'm looking for a coil rear end for my 68 c10 that the spider gears are going out in. I want to find a rear end I can use until Incan rebuild my original the right way. After multiple yards I found one. A coil rear from a 72. But it is 5 lug. Can I use the 6 lug axels from the original rear Can I swap the six lug axels into the junk yard rear end and be good to go. With out any mods just want to swap it out and be on the road
Thanks Posted via Mobile Device |
Re: Need quick Rear end help!!
no the 5 hole axels are longer 3/4'' i believe
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Measure the rear end from backing plate to backing plate.
Your 68 rear end will probably be 55.5" at this point. The 72 5 lug axle will be 57" So, I'm thinking no. The only exception is if your rear end was a 69-70 some (I have one) from the late 69-70 model year were 57 " wide, but still 6 lug. 5 lug originals are usually 57" plate to plate. I'm thinking pass .. (unless you want to swap the front to 5 lug? .. and of course wheels too.. )
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Correct -- .75" either side. 1.5" overall wider. 55.5" vs. 57"
One more thing .. you'll want to be careful if you have wider wheels and tires on it too. If you swap to a 57" rear end, your wheels will 'stick out' .75" more on either side.
(cause her butt will be wider ![]()
Active Member
My gosh thank you for the quick responses I will measure
Active Member
Yup 55 my old rear and 57 junk rear. Thanks guys for saving me 200 bones and a head ache
