Old 05-31-2003, 03:23 PM   #1
kens67chevy
Question body drop question?
I have '67 chevy 2wd and i'm putting a 2" body drop in it. for the cab i raised the floor and the box the same thing. for the front i haven't done anything yet because i m not sure where to make the cut.
iam pretty sure i need to cut the frame, but where is the question. I know it has be in front of the motor mounts, but then what do i do with the steering gear box???
any suggestions will help
thanks alot guys
ken
kens67chevy is offline   Reply With Quote
Old 05-31-2003, 05:54 PM   #2
SCOTI
SCOTI's Avatar
You actually would just need to lower the radiator core support mounts equal to the amount of the body drop. This in turn lowers the front of the fenders the proper amount to line up w/the cab & won't effect steering gear (other than from the box to the cab).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2003, 05:40 PM   #3
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Thumbs up
I cut about 6" of the very front frame rails and lowered them 2.5" for mine. This way the bumper, inner fenders, etc lined up. The sterring box is untouched and in the same spot. As for the rad i just drilled new holes in it and lowered it about 1.5" and the hood closes! so i am happy.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 06-03-2003, 01:45 AM   #4
orange72
orange72's Avatar
yea i cut mine right at the point where the little crossmember under the fan is..ill post a pic..just make sure you cut enough back to clear the radiator and hoses.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 06-03-2003, 10:16 AM   #5
SCOTI
SCOTI's Avatar
You'll need to modify the shroud or switch to an electric fan set-up too . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2003, 09:12 AM   #6
kens67chevy
thanks guys that helped alot.
the pic will come in handy!!
thanks again
ken
