Old 10-24-2012, 02:38 PM   #1
496bb
496bb's Avatar
identify 3/4 springs 67-72
I think my 69 C20 has the stiffest springs possible. Unloaded, the back end is super stiff- and since I won't be hauling loaded most of the time, I would like to soften the ride some. PO told me he had loaded it down with rock and it barely sat down- even without inflating the airbags installed on the rear. I have searched the forum, and read that there were 2000lb or HD 3000 springs. Nothing left with the truck to help identify what options it has. How can I identify 3/4 rear coil springs, so I can determine which I have, and also if I do have the HD version- so I can identify the softer version.
496bb is offline   Reply With Quote
Old 10-28-2012, 02:29 PM   #2
496bb
496bb's Avatar
Re: identify 3/4 springs 67-72
nobody?
Old 10-29-2012, 04:15 PM   #3
69gmcc10
69gmcc10's Avatar
Sorry we have not been more help. It is difficult to visually determine what springs are what, but there are tests you can do to determine what rate they are. I am not smart enough to tell you the math involved because it has to do with adding weight in the rear of the vehicle until it moves a certain distance, the leverage of the arm that the spring is on and the Chinese yen. If you search spring rate calculations I am sure you can find something.
Again, sorry, I wish I could be of more help.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-30-2012, 09:01 AM   #4
496bb
496bb's Avatar
Thanks anyway. I figured maybe there was a difference in thickness of the steel- coil height and diameter would be the same, but something is different and maybe no way to tell without an actual test. These air shocks probably aren't helping matters either, so I am gonna replace those with some new regular shocks.
Old 10-30-2012, 11:17 AM   #5
69gmcc10
69gmcc10's Avatar
sens-a-trac shocks are a real popular here, I have a set and really like them. you can pick them up for a very reasonable price as well.
