Welding on a painted floor - ideas?
I'm doing subframe connectors on my Camaro, and it will entail a lot of welding under the car (mostly MIG). Unfortunately I just had my shop floor coated (that speckle finish) last fall, and it's not burn proof.
I'm wondering what I can put down on the floor that will protect it. I was thinking perhaps a sheet of plywood that soak with a hose first, but slag will likely still ignite it. Perhaps drywall (gyprock), but that has a paper coating. Obviously a big sheet of steel or a pile of sand would work, but those aren't really practical, so I'm looking for any good suggestions!
Re: Welding on a painted floor - ideas?
I'd think just a couple of sheets of OSB or plywood would be fine. Just keep a mop and a bucket of water handy. Then just hit it as it dries or starts to smolder too much. Or maybe some of the tile backerboard over a tarp.
But if you really want to get fancy build a couple of 4x8" 2x4 framed sheets of plywood on casters with a layer of sand. A portable sandbox/sandtable for your toys.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
3M Welding paper ? Superflysteiney used it when welding up a custom raised bed floor in a freshly painted truck in his "tootsie..." build.
http://3mcollision.com/3m-welding-an...per-05916.html Edit: just read the description: not designed for horizontal surfaces, Doh How about a welding blanket? http://www.toolking.com/lenco-08820-...FQhyQgodYkwA2w
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 10-24-2012 at 06:21 PM. |
#4 | |
Works Great, too! |
I am a Referee of life.
I would get a welding blanket or two.I have heard but never tested that you could soak a wool Army Blanket in a strong borax solution then airdry it and it would fireproof it.You might want to put a sheet of plywood down with a welding blanket over it to prevent heat transfer.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Sep 2009
a welding blanket is what you need
The Older Generation
You could also go to the home center and get a few sheets of ceramic tile backer board (I always called it cement board) That would work. LockDoc
I always look for the simplest solution myself. Weld it in the driveway.
#9 | |
I've been watching this thread myself because I just painted my new floor in my new shop and don't want a bunch of burn marks on it either. I'll be ordering myself a welding blanket when I "move in" to my new shop. Another problem with "in the driveway" where I live is that pretty soon it will be below zero out there. Its pretty tough to control your weld puddle when you're shivering. ![]()
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
1972 K20
![]() Join Date: Apr 2008
I keep a 3 x 6 sheet of sheetmetal in a corner and whenever I do any cutting with a torch I place it under the work area. Your creeper or whatever rolls right over it.
The 3M weld paper is great but it is like $ 100 bucks a roll. I have a fibreglass welding blanket that I put up when I am welding on rocker panels and door opening and such [doing one today in fact] I also have some tile backer board from the bathroom remodel here at this house and our rental hosue down the street[it is concrete or something like it] Try to have a fire ex. handy I know it is a know brainer but I almost lost my whole shop a couple years ago cause akid working for me cut a floorwith a plasma and hit a fuel line and did not have one near by. He freaked started runing and the fire was sucking the gas from the tank and kept feeding the fire! Just please stay safe most of all and have fun, and you problem may be as simple as a wet down with a water hose? Jim
