Old 10-24-2012, 09:08 PM   #1
Mark3100
Mark3100's Avatar
Cool 49 C3100 Axle Swap
Hey - I just got a 49 C3100 and I'm currently replacing the front and rear suspension. I'm putting in a Mustang II IFS with 11" disks and power rack - (start welding it in on Friday). I'm also currently trying to find what rear axle assembly to use. The original axle is 62" hub to hub and the wheels I'm looking at have a 4.5" or a 5.625" backspace so I need a 62" or a 64" axle width to keep the correct fender spacing. Have any of you replaced the rear axle with a newer axle and if so, what was it taken out of? I hear a C10 may work but can't find any info. Any help would be greatly appreciated. If anyone would like me to post anything about the Mustang II IFS install, I would be glad to share - it is a Helix! (Oh, I want a 5-4.75" bolt pattern).
Thanks - Mark!
Mark3100 is offline   Reply With Quote
Old 10-24-2012, 10:55 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 49 C3100 Axle Swap
Ford 8.8? I've seen a few builds with them sorced from explorers and f150 I think, but I'm not a ford guy
NEWFISHER is offline   Reply With Quote
Old 10-24-2012, 11:02 PM   #3
PurdueSD
PurdueSD's Avatar
explorer axle is 59.5" wide and will require reversed wheels or a backspace in the 2.5" neiborhood. The camaro 10.5 is the popular swap. I think its around 62" wms to wms.
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 10-25-2012, 02:13 AM   #4
gregw98
gregw98's Avatar
I am doing a 79 Camaro swap right now.
gregw98 is offline   Reply With Quote
Old 10-25-2012, 08:10 AM   #5
solidaxel
solidaxel's Avatar
Welcome from So Arizona!
I have two AD trucks with Camaro rear axles and I have 255 70 15 tires on 8" wheels with a center back spacing and they work fine.
What gear box are you using?
That may depend on what axle ratio you pick
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-25-2012, 09:37 AM   #6
Mark3100
Mark3100's Avatar
Thanks for the info! So, Camaro it is. What suspension are you using - 4 link or leafsprings? I was thinking of just using a TH400 (I'm putting a 350 into it) but I would really like an overdrive so .... Once I get the suspension set, I'll start looking at tranny's. I was thinking of using 255/45-17's or 245/50-15's. They are basically the same size tire but I have more options with the 17's.
Old 10-26-2012, 10:23 AM   #7
mknittle
mknittle's Avatar
I am using a 76 Monty Carlo it is 62" I am also using the Monty Carlo triangulated 4 link.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-26-2012, 10:03 PM   #8
Mark3100
Mark3100's Avatar
Today I purchased a Posi from a 79 Z28. It eas in great condition and I paid an extra $100 for the full leafspring setup. I'm really pleased with what I got. So I'll have a Mustang II front end and a Z28 rear axle. Should be a great setup! I'll post pictures as I go!
