Old 10-24-2012, 09:23 PM   #1
62 bigwindow
62 bigwindow's Avatar
Any advice or help installing high hump
Thought I would ask you guys who have already done this if you had some advice or pointers to help.. I am installing high hump in floor of my 66. Looks to be pretty simple but thought I would ask how other people have done it and if they had any pics of the install....thanks guys
62 bigwindow is offline   Reply With Quote
Old 10-25-2012, 12:18 AM   #2
Captainfab
60-66 Nut
Re: Any advice or help installing high hump
Does the '66 cab have a non-removeable low hump? Did you get both pieces for the high hump conversion?
Old 10-25-2012, 05:48 AM   #3
62 bigwindow
yes the cab has the non removable low hump.. and i did get both pieces for the high hump. I got the low hump cut out so i could start fitting the 2 high hump pieces in.. just thought I would ask if anybody had some advice or pictures to make install as easy as possible
Old 10-25-2012, 09:04 PM   #4
Ta2Don
Ta2Don's Avatar
Watching this thread, will need to do this job on mine in order to run the tranny I want to use...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 10-26-2012, 12:21 AM   #5
Captainfab
60-66 Nut
I don't have any install pics, but I do remember seeing some in someone's build thread. I just don't remember who's
I would suggest starting with cutting the hole in the floor, smaller than you think it should be. You can always cut it bigger, but making it smaller is a bit more work.
Old 10-26-2012, 06:14 AM   #6
DURG
DURG's Avatar
I have pix in my build thread.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
