Noise When in Neutral
Start off i have a 350 mated with a sm465 transmission and a np208 transfer.
axles are dana up front and gm corp 12 out back 1/2 ton i just got the truck back on the road. today was the first real test drive. everything is great off the line, shifts smooth engages good. but as soon as i start to decelarate it starts to make a grinding noise, if i put it in neutral it makes it more and if i push the clutch in it doesnt go away. espcially does it when i put the truck in neutral down hill if i put it back into gear it goes away right away. what could this noise be? all fluids are topped off with fresh oil.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
| Bookmarks |
