10-25-2012, 12:56 AM | #1 |
Quick Ratio Power Steering Gear Box
I would like to swap out the power steering gearbox on my 68' for a quick ratio box. I believe the 73' gear box is quick ratio and a direct fit. I would need to use a 68' pitman arm.
Do I have this right? Is there anything else I should know?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
10-25-2012, 01:08 AM | #2 |
Re: Quick Ratio Power Steering Gear Box
Hey what's up ,
Think I talked to you and your buddy with the blue c10 at good guys in ft worth I was with my brother in law behind you guys with the dark blue C10. I was want to know who did your interior ? I just got all new glass in and now looking For a trim guy . Thanks mike Posted via Mobile Device |
10-25-2012, 01:58 AM | #3 | |
10-25-2012, 02:29 AM | #4 |
Not absolutely sure but I dont think any truck box is quick ratio, you have to put quick ratio car box guts in a truck box to get quick ratio.
10-25-2012, 02:48 AM | #5 |
Collector of Projects
I went with a 76 4x4 box on the K5. I believe it was variable ratio and less turns lock to lock... check with Red Head at www.redheadsteeringgears.com
10-25-2012, 08:41 AM | #6 |
Hey AusTx68
Where at around Dallas are you moving to ? We are actually south of Dallas , Probably 10-15 miles . Yea I'm still trying to figure this board out . Hit me with your trim guys number . Let me know when you get in town . Posted via Mobile Device |
10-25-2012, 08:58 AM | #7 | |||
Ralph's Upholstery 105 West Brenham Street Elgin, TX 78621 (512) 285-2669
10-25-2012, 09:20 AM | #8 |
67-72 parts collector,…
Member gringoloco just installed a Redhead box.
You might give him a shout. http://redheadsteeringgears.com/index.html
10-25-2012, 12:36 PM | #9 | |
10-25-2012, 12:39 PM | #10 |
Mine was a 76 I believe and it is 1.5 turns to lock from center.
10-25-2012, 12:52 PM | #11 |
Did the 76' steering box bolt right up?
10-25-2012, 01:02 PM | #12 |
I just installed a box from a 77 c-10. It is not quick ratio 3 turns to lock from center. It bolted right up and looked exactly the same as my 70 original gear box.
Ebay has a New GM overstock gear box for $190 no core charge, that I found after I bought the 77. http://www.ebay.com/itm/77-78-79-80-...30482035194%26 Says it fits 67-84 two wheel drives
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
10-25-2012, 01:12 PM | #13 | |
Mine bolted right up in my 67 and used the old pittman arm too! |
10-25-2012, 02:19 PM | #14 | |
10-25-2012, 02:28 PM | #15 |
Just got off the phone with Oreilly's. They have a gearbox for $125 with $50 core. That pretty good but it's standard ratio.
10-25-2012, 04:20 PM | #16 |
My Bad, missed that.
10-25-2012, 07:44 PM | #17 |
I am a Referee of life.
IIRC when I researched this,the standard PS box for a 68-72 was 4 1/2 turns lock to lock.The later boxes 73^ were 3 1/4 turns.The later box doesn't feel as "mushy" to me so that's what I went with.I did use a pitman arm to match my front suspension.
BTW I think the later box is VR.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-26-2012, 01:16 AM | #18 |
All the boxes will bolt to the frame. It's the type of hose fitting that changed in the lates 70's and I'm not sure of the year. It went to the bubble flare type and your existing high pressure hose will not fit... I bought a set of -6 AN fitting adapters that fit the steering box but I am upgrading to hydroboost....
10-26-2012, 04:39 AM | #19 |
the ? is what year did they quicken the ratio. cant answer but '73 seems too early. don't think you'll need a another pitman arm. another thing as mentioned was what year did they change the fittings? can't answer that either. the years for a bolt in swap are narrow, i think maybe only 3 or 4 years. what ever my ebay box was it came with the pitman arm and it fit, for the line fittings i had to get adapters, different rag joint too. if you get the wrong year is no biggie just a little more scratch to make it work. everything is available.
10-27-2012, 03:59 PM | #20 | |
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
10-28-2012, 05:15 AM | #21 |
OK. So today I got pulled my RedHead 4WD box to swap for a 2WD box from what was supposed to be an 88 3/4 ton truck. The RedHead invoice syas 69-76 GM 4X4, so I will ASSume that 77 and newer had different hose connections and at some point (maybe 77 also) the diameter of the splined input shaft was reduced.
I had rebuilt my steering shaft rag joint when I replaced the word out box for the new RedHead box, so I'll try and make a hybrid rag joint using the new rubber with late model female spline piece. If that doesn't work I'll drill/punch the pin out that connects the two shaft halves and try to make the connection there.... I'll try and take pics Sunday afternoon.... |
10-28-2012, 08:39 PM | #22 |
Here is another source
http://www.powersteering.com/
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
10-27-2013, 02:07 AM | #23 |
I know this is an old thread, but does anyone have Any idea if early trans am/ z28 boxes will bolt up to our trucks? I have used 73+ boxes in the past, but im looking for a fast ratio box this time around.
I just remembered that the car box bolts inside the frame and the truck on the outside. Last edited by WIDESIDE72; 10-27-2013 at 02:15 AM. |
10-27-2013, 09:29 AM | #24 |
2WD Jimmy
Early Classic Enterprises has a drop in quick ratio boox. Thats what I am using.
10-27-2013, 09:47 AM | #25 |
Yes, I use it too and it works GREAT on my 67!
