Old 05-31-2003, 05:21 PM   #1
67_396
Ignition switch??
Im trying to get my dash out to do some work on it, but I cant get the ignition switch out. Can someone please tell me how to get it out?
67_396 is offline   Reply With Quote
Old 05-31-2003, 08:32 PM   #2
JimKshortstep4x4
Talking
Turn the switch to accessory and use a straightened out paper clip or equivalent to depress the small pin in the small hole. Once the pin is depressed, you should be able to continue turning the switch to the left and then it will come out.
Jim
Old 05-31-2003, 09:13 PM   #3
Blue Beard
Blue Beard's Avatar
Are you trying to get the entire unit out or just the cylinder?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-31-2003, 11:03 PM   #4
67_396
I want to get the entire unit out
Old 05-31-2003, 11:08 PM   #5
Class of 69
Class of 69's Avatar
You need to turn out the outer bezel...I think after you remove the cylinder. There are small indentations in the bezel for a special spanner wrench, or whatever ingenious method of turning it you can come up with.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 06-01-2003, 09:19 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
A small allen wrench works better than the paper clip. The clip bends too easily.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
