Old 10-25-2012, 11:13 AM   #1
harley rider
harley rider's Avatar
How low are you goin and still towin?
I want to lower my 67 and still be able to tow a loaded car trailer or or 20 ft camper.how low are you going and how did you do it? lets see some pics with attached trailers.
harley rider is offline   Reply With Quote
Old 10-25-2012, 12:10 PM   #2
ColoradoK5
ColoradoK5's Avatar
Re: How low are you goin and still towin?
Here is "NACHO" doing work!!
ColoradoK5 is offline   Reply With Quote
Old 10-25-2012, 03:02 PM   #3
c10srule
c10srule's Avatar
now thats low, really cool, keep on truckn
c10srule is offline   Reply With Quote
Old 10-25-2012, 03:43 PM   #4
harley rider
looks like there is no limit. is that on air ?
Old 10-25-2012, 04:49 PM   #5
99-LS1-SS
99-LS1-SS's Avatar
I plan on towing with a static 4.5/5.5-6 drop. I will have to see how that works out.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 10-25-2012, 04:53 PM   #6
ColoradoK5
ColoradoK5's Avatar
Here is the build thread alot of great info on o great build good read.
http://67-72chevytrucks.com/vboard/s...ighlight=nacho
Old 10-26-2012, 09:56 AM   #7
harley rider
is that it one guy using a lowered truck to tow? by the way nice truck cok5.
Old 10-26-2012, 11:14 AM   #8
chopnchaneled
chopnchaneled's Avatar
My 68 stepper is 4.5 in the front and 6.0 in the rear, I pull my bass boat with it and no problems.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 10-26-2012, 05:44 PM   #9
harley rider
so how did you get it that low in the rear ? and what kind of springs are you using?
Old 10-26-2012, 05:55 PM   #10
harley rider
maybe I should change my question. I know how to lower it. what I want to know is what after market lowering springs will take a load? are they all about the same or are some better.
Old 10-26-2012, 06:05 PM   #11
windmill
windmill's Avatar
heres mine should be lower when i finished...
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 10-26-2012, 06:22 PM   #12
stomper
Junior Member
stomper's Avatar
I have a 4/7.5 ish static. This is my buddies jet ski. No problems but it is light. I'm planning on bags in the rear so I can pull my car trailer or boat. The way I see it is, being lowered you don't have much room for squat from the tongue weight. Any spring that wouldn't compress much is going to ride hard.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 10-26-2012, 09:01 PM   #13
Rob68c10
You guys running a c notch or something? I dropped my 68 4/6 and I know it's very close to the bump stops.
Rob68c10 is offline   Reply With Quote
Old 10-26-2012, 10:30 PM   #14
windmill
windmill's Avatar
i have drop leaf springs,,,
72 swb pickup
1967 chevelle ss
Old 10-27-2012, 09:09 AM   #15
chopnchaneled
As far as i know there all about the same on rates.
You asked what springs i used, ece supplied them,and yes i'm close
to the bump stops and depending on the road hit them on ocassion.
the only way i know of get a higher rate spring is getting eaton spring
to make some. Heard of some folks using air bags on the trailing arms
for when hauling a load.
hope this helps
Old 11-14-2012, 09:47 PM   #16
cheyenne shortstep
cheyenne shortstep's Avatar
Drop spindles with 3/4 coil cut front, heated springs rear.
cheyenne shortstep is offline   Reply With Quote
Old 11-14-2012, 10:12 PM   #17
classicchev
classicchev's Avatar
Not a 67 72, but full air ride!! cruise and pull with no problems
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 11-14-2012, 11:17 PM   #18
jhwkns
Registered Cruiser
jhwkns's Avatar
Hooked up to my new buggy trailer.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-15-2012, 02:36 PM   #19
brad_man_72
the boat guy
brad_man_72's Avatar
4 6 drop, springs. Hits the bumpstops with a load or hauling but I haven't died yet.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-15-2012, 03:36 PM   #20
original-71
///Relaxed Atmosphere
original-71's Avatar
not much weight but it gets the job done. E.C.E 6 inch rear coil and half inch block trimmed the bump stops about a half inch no rubbing.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 11-15-2012, 03:43 PM   #21
Billett
Billett's Avatar
Not a 67-72, but the sky is the limit really.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 11-15-2012, 03:51 PM   #22
Hart_Rod
Hart_Rod's Avatar
I think you meant to say "the ground is the limit"................
Hart_Rod is offline   Reply With Quote
