Old 10-25-2012, 12:42 PM   #1
JoeyBones
Column - turn signals/brights
Ok guys, I have a 1987 here and the previous owner swapped in a 1994 tilt column. Everything seems alright except that when you are making a turn, the wheel won't click the signals off, and the pull switch for the headlights doesn't click and doesn't do anything having to do with the high/low function of the lights.
I realize this is my first post, but I really couldn't find a whole lot of specific info on these items. (also this is the first vehicle this old I've owned and haven't had to deal with some of these issues before.)
Thanks in advance!
JoeyBones is offline   Reply With Quote
Old 10-25-2012, 02:13 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Column - turn signals/brights
The turn-signal cancel cam is missing parts or it's damaged.
The hi-low function is handled by the turn-signal stalk. Just pull it toward you till it clicks and it will change to the opposite position... either Hi or Low... If it isn't working you can replace the switch at the base of the steering column. You'll need to drop it down to access the hi-low beam switch.
The dash mounted combination light switch
turns on the headlights,
turns on the dome and floor lights,
and dims the dash lamps.
It won't "click" but it has a stop detent halfway up. If the detent is a little sloppy or it's malfunctioning or it bothers you you can replace it.
Maybe I misunderstand you... What are you expecting the dash switch to do?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-25-2012, 03:19 PM   #3
JoeyBones
You were right, I was misleading. I meant the switch in the turn signal stalk...I just wasn't sure where it was or what to look for. I'll look around the base of the column.
I appreciate your help. sounds like i need to disasemble the column to get to the turn signal cancel cam huh?.
Old 10-25-2012, 04:51 PM   #4
hatzie
Moderator
hatzie's Avatar
I've never had issues with the cancel cam. It lives right behind or almost right behind the steering wheel.
The dimmer switch could be as simple as the actuator rod being unhitched from the dimmer switch or lever. I've never had problems with that either so I never had occasion to pull it apart...
This is a parts manual blowup of the 87-91 RV series column. The 94 CK column, since it fits, is probably not that different.
Old 10-25-2012, 04:56 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
if the wheel is out 180 degres
the cam won't work in the right spot
does it cancel at all on a "full "turn
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-26-2012, 08:10 AM   #6
JoeyBones
I've actually never tried that. I will give that a shot this weekend. I really appreciate all the help. I'm going to be ordering a replacement rag joint to hopefully correct some sloppy steering as well!
