Old 10-25-2012, 02:39 PM   #1
Iceman_70
Iceman_70's Avatar
Mustang II IFS
I’m considering to install a Mustang II IFS on my 56 chevy truck… I thought I saw somewhere on the net that the MII with standard spindles will lower the front with 4” … is this correct ?
Any suggestions to lower the back 4” as well ? I saw some people flip the rear, but if my estimates are correct this lowers the rear 7”-8”
Iceman_70 is offline   Reply With Quote
Old 10-25-2012, 04:21 PM   #2
_Ogre
_Ogre's Avatar
Re: Mustang II IFS
flipping the rear on top of stock springs will lower the back 7''
i have a fatman mustII and it looks like this
shop air compressor timer
Old 10-25-2012, 04:47 PM   #3
Highsider
Highsider's Avatar
Re: Mustang II IFS
Looks great, Ogre!
Highsider is offline   Reply With Quote
Old 10-26-2012, 05:53 AM   #4
Iceman_70
Iceman_70's Avatar
Re: Mustang II IFS
I already read through your build, but must have missed the front/rear setup ... This is really looking nice ...
Old 10-26-2012, 09:03 AM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Mustang II IFS
Ogre, Your truck DOES look just right. May I ask how wide your rims are and if you have any rubbing issues on turns? Did you C notch the rear?
Dan in Pasadena is offline   Reply With Quote
Old 10-26-2012, 05:43 PM   #6
_Ogre
_Ogre's Avatar
Re: Mustang II IFS
i should have added... fatman mustII with standard front spindles
i can't imagine having 2'' more of drop, it wouldn't be streetable.
at dip: (you chose that name not me )
with the fatman and 3rd gen rearend i use 7x15 up front and 8x15 in back, both with 4'' back spacing
all with P235/70R15 black walls, though i will go with skinnier tire up front next time.
fronts rub a bit locked to the right, barely
backs have 3'' mini tubs in the bed and i can barely get my pinky between the fender and the tire.
and yes to the c-notch. 3'' c-notch. but go with 4 or 5 instead, i had to put air shocks on mine.
