Old 10-25-2012, 10:24 PM   #1
z67
need some help with a T5 install
I have a 67 c10 long box with a 4 speed floor shift, with granny gear bolted to a 327, and it looks like I have a high hump 6". I've been looking at a lot of threads in the last week and have not been able to locate anything that talks about if the t5 will work in a high hump? Also, my 4 speed does not look like anything that I have found in the pictures. Mine is very short with no tail end. The shifter boot is very close to the dash. Has anyone done this t5 swap in a 67-72 chevy truck...have any pictures as to where the shifter will end up? Also, how can i find out what gear ratio I have in the rear axle without taking the back cover of? what's the most cost effective way a t5 or a 700r4 ? I'm thinking the t5 since I already have the clutch setup and won't have to chance my steering column, any help is very much appreciated
z67 is offline   Reply With Quote
Old 10-25-2012, 10:29 PM   #2
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: need some help with a T5 install
There are some very fine threads in the FAQ section on T5 swaps, One by Brad, and another by Jocko
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-25-2012, 10:32 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Did you see this how to....
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
Pretty comprehensive.
LockDoc
Leon
Old 10-26-2012, 10:24 AM   #4
z67
I looked ad both of them but still need more questions answered
Old 10-26-2012, 10:34 AM   #5
j ripper
j ripper's Avatar
I too have been considering this swap. I have pretty much the identical truck as you. These tech threads pretty much sum everything up. You will have no problem getting that trans under a high hump. I would locate another hump cover to cut the hole so you don't ruin the orig one. The camaro gearbox with the s 10 tail seems the way to go!!
edited by staff
j ripper is offline   Reply With Quote
Old 10-26-2012, 10:59 AM   #6
z67
Just need to know If the shifter will reach to the top of the hump.
