10-26-2012, 01:54 PM | #1 |
need help!
Installed my 496/th400 last night and there is a noise coming from bellhousing area. It almost sounds like a fan hitting a fan shroud but is most definitely coming from bellhousing area. It doesnt appear anything is rubbing. What can i look for?
Also im running a holley double pumper and throttle cable is too long for carb. Does holley make a throttle extension for their carbs so i can get the throttle cable to mount farther towards front of truck? Posted via Mobile Device
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
10-26-2012, 02:03 PM | #2 |
Re: need help!
remove dust shield on the bottom of the tranny and see if that is what is causing noise
while it is off check flexplat and torque converter for a wobble while running
10-26-2012, 02:04 PM | #3 |
Re: need help!
Do you have the bellhousing cover on? It could be bent and rubbing the flywheel.
10-26-2012, 02:05 PM | #4 |
Re: need help!
The dust shield is off and will check for wobble
10-26-2012, 03:54 PM | #5 |
Re: need help!
No wobbling that I can see. Eliminated the possibility of it being water pump, clutch fan, power steering. I guess I will try to shim the starter and see what happens.
10-26-2012, 06:08 PM | #6 |
Re: need help!
we had a problem like that with a high torque starter once had to shim the nose farther away from the body, the flexplate was hitting the starter teeth
10-26-2012, 10:43 PM | #7 |
Re: need help!
Well tried shimming starter and torque converter and unhooked flex plate from torque converter. No dice. Still making noise
