Old 10-26-2012, 04:28 PM   #1
cameyer
Brake lights not working
Hopefully someone can help me, I have a 64 chevy k10 and just replaced the steering column with an ididit steering column. after getting everything back together the brake lights did not work. The turn signals work and the 4 way flashers work, but no brake lights. Today i picked up a new brake light switch and still no brake lights. where do i go from here?
cameyer is offline   Reply With Quote
Old 10-26-2012, 04:44 PM   #2
hopped up
hopped up's Avatar
Re: Brake lights not working
Check your fuse
hopped up is offline   Reply With Quote
Old 10-26-2012, 05:08 PM   #3
cameyer
Fuse is still good
Old 10-26-2012, 05:13 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Check for power at the terminals ( brake light switch, rear harness at the firewall behind ds head, tail light plug) in this order.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-26-2012, 05:15 PM   #5
cameyer
Just got a new brake light switch and it seems to be operating fine. Could it be the flasher?
Old 10-26-2012, 06:33 PM   #6
tincan1966
tincan1966's Avatar
The flasher has nothing to do with the brake lights. The orange wire at the brake light switch should have 12V at all times. The white wire coming off the switch should have 12V with pedal depressed,sending power thru the turn signal switch.With the pedal depressed, and power on the white wire, check the yellow and green wires at the turn signal harness connector. Check both sides of the connector, in case a terminal is not completely seating in the plug in. If all three are hot with the pedal pushed, then follow from there towards the back. My guess would be the T/S switch or connector. if all was working before and the column is the only thing that changed, then the problem is there.
Occasionally, on some types of turn signal switches, if the hazard switch is on(4 way flashers) the brake lights will not work.
tincan1966 is offline   Reply With Quote
