10-26-2012, 07:32 PM | #1 |
frame help
looking to buy a frame and just do a swap of motor, trans, beds, cab, and front clip. What year frame is interchangeable for a 68 swb?
1968 CHEVY C10 THE NEVER ENDING PROJECT
10-26-2012, 09:04 PM | #2 |
Re: frame help
ttt
10-26-2012, 09:08 PM | #3 |
I am a Referee of life.
Re: frame help
67-72 chvy or GMC.Chevy came standard with coil springs buut GMC were leafs.You could option either one either,but bodies and drivelines will swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-26-2012, 09:13 PM | #4 |
Re: frame help
If i'm not mistaken the front radiator support mounts for the 67-68 were in a different location or a different mount all together from the 69-72. You may wanna keep that in mind and adjust as needed.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
10-26-2012, 10:16 PM | #5 |
Re: frame help
so how can i make sure im not getting the wrong frame
10-26-2012, 10:28 PM | #6 |
Re: frame help
The V.I.N number is stamped on the frame. One is just above the steering box. The 5th digit is the last number of the year. It would be possible to swap the front supports to get the correct ones for the front clip. I am 99.9999% sure that the front supports are different. Hopefully someone will chime in and back me on this info.
10-26-2012, 11:26 PM | #7 |
Re: frame help
they are different
