Old 10-26-2012, 07:36 PM   #1
HTX86chevy
HTX86chevy's Avatar
vent window seal question
Any one know how to determine the year that the doors or vent windows were made. I see on some websites that there are three different Seal style for different year Trucks.
73-80
81-85
85-91
my passenger door window motor burned up and the motor is from a 70's door.
I am assuming that the door was replaced at some point. I am not sure about the driver side yet. I am hoping to find out a way before pulling the vent windows as this is my daily driver.
HTX86chevy is offline   Reply With Quote
Old 10-26-2012, 08:41 PM   #2
J Knight
J Knight's Avatar
Re: vent window seal question
Lmc only shows two vent window seals 73-80 and 81-87. 85-91 had 2 instead of 3 mounting points in the door jam above the door hinge for the whole vent window assembly. One way to possably try to identify the difference in the seal is that 73-80 had thicker glass than 81-87. Also I think the latch on the 73-80 didnt have a locking button option but not sure.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-26-2012, 10:56 PM   #3
HTX86chevy
HTX86chevy's Avatar
I swapped the old pitted handles for new ones awhile back, but I belive the old ones had locking buttons also. Anyone know the Glass thickness differences?
Thanks!
Old 10-27-2012, 10:06 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i switched 89 vents,glass,panels to my 78
older thicker glass,almost X2 newer
havn't seen any old vents with locks tho
older has steel clips on rods newer has plastic clips...
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-27-2012, 01:08 PM   #5
1981Stepside
1981Stepside's Avatar
LMC's catalogue is incorrect with the listing of 1 piece seals from 81-87. I found out the hard way. 81-84 had 2 piece seals. Your best bet is to roll the window down and gently pull the window track felt out of the back of the vent window frame. If you see a couple of bent metal tabs then you have a 2 piece seal. If the latches have (had) locks on them then I would say you need these seals (81 and up) :
http://www.brotherstrucks.com/prodin...number=VWW8191
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 11-14-2012, 11:40 AM   #6
Precision Parts
Tech Help
Precision Parts's Avatar
A little late here but wanted to reaffirm this post. This is one of the single most complaints I hear from customers!
73-80 - 2 Piece Style
81-85 - 2 Piece Style
85-87(91) 1 piece style
The above post is correct in how to identify which 2 piece version you have. The 81-85 has tabs that insert into the division post and fold over, so removing the glassrun on the division bar (where the door glass rolls up) will expose these tabs (81-85) or rivet heads (73-80). There's so little tolerance in these weatherstrips so they can not be interchanged without problems arising.
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 11-14-2012, 10:36 PM   #7
v30crewcab
v30crewcab's Avatar
hmm, maybe thats been my issue all along. I think my vent windows are stock 84-85 cucv ones, since my doors came from a cucv. I have 1piece seals in them since my truck is an 88. might have to try a different set.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-15-2012, 01:35 PM   #8
HTX86chevy
HTX86chevy's Avatar
not late at all.... I haven't gotten around to even checking for the Tabs or rivet heads until today. Thanks for the tips guys, it made identifying a lot easier.... I tried to remove the rubber from the door slowly, but the crap just crumbled to pieces! anyway, here is a pic of the Tabs that are on both vent windows. I only want to do this project once for the rest of my time owning this truck.... what else should I replace while I am in there?
Old 11-15-2012, 01:57 PM   #9
HTX86chevy
HTX86chevy's Avatar
Precision Parts, From your website, I have 3 Items that I would like to purchase, but would like your opinion if you think they are correct for my year truck.
I have : Door Weatherstrip Seal fits 1973-1987 Chevy Truck
(DWP 1110 73)
Glass Run Channel Weatherstrip fits 1981-1987 Chevy Truck, 1981-1991 Blazer, Suburban
(GRR 1110 81)
Vent Weatherstrip Seal Kit fits 1981-1985 Chevy Truck, 1981-1985 Blazer & Suburban
(VWK 1110 81 A)
Mine have the Tabs, so these are correct for my truck even though mine is an 86?
Old 11-15-2012, 02:11 PM   #10
Precision Parts
Tech Help
(DWP 1110 73) Door opening weatherstrip for both doors
(GRR 1110 81) This is the glassrun for the right side only
(VWK 1110 81 A)
Mine have the Tabs, so these are correct for my truck even though mine is an 86? Yes, you must get the tabbed version. It's rare to see this on an '86 but you're not the first!
If you need the glassrun for the left side you'll find it here: http://precisionrestorationparts.com...-suburban.html
Let me know if you have any questions.
Derek
PRECISION
Updates
Old 11-15-2012, 06:21 PM   #11
HTX86chevy
HTX86chevy's Avatar
Thanks a lot & another thanks for the heads up on the Leftside Glassrun.
Old 11-22-2012, 11:17 AM   #12
Greenlee
Greenlee's Avatar
So it sounds like from what I'm reading that a 1 piece seal cannot be used in place of a 2 piece seal?
I was getting ready to put mine back together, but I think I may have the wrong part. I removed the vent window I am using from a 1989 Suburban. It is the 2 piece type with the tabs.
Greenlee is offline   Reply With Quote
Old 11-22-2012, 01:09 PM   #13
Precision Parts
Tech Help
I've never seen this on an '89 before. Very unusual, but nothing surprises me on these two piece designs anymore.
Some people do make them work, whether they are using a lot of weatherstrip adhesive or urethane...I'm not sure. The bottom line is that most people encounter problems, wind noise, leakage etc. Get the correct ones. Your truck, time & sanity are worth it!
Derek
PRECISION
Updates
