Old 10-26-2012, 09:51 PM   #1
lil_sahara450r
Where to find 73-87 a arm u bolts??
Hey gang! I'm doing a complete front end rebuild on my 66c10 and I'm going to hang the lower a arms using the thicker and beefier 73-87 style u bolts (advice taken from this board). Just wandering where I could get some of these without going to the junk yard? I went to the local O'reilys but they didn't know what I was talking about (they are worthless here, anyone else have that problem??).
So.... Where can I get some? Thanks guys!
lil_sahara450r is offline   Reply With Quote
Old 10-26-2012, 10:05 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Where to find 73-87 a arm u bolts??
Classic Parts of America
http://www.classicparts.com/
Pro Performance is offline   Reply With Quote
Old 10-26-2012, 11:26 PM   #3
lil_sahara450r
Thank you!!
Old 10-27-2012, 03:09 PM   #4
bodydropped68
bodydropped68's Avatar
Local auto parts store the motormite # 13503 in the help section
bodydropped68 is offline   Reply With Quote
Old 10-28-2012, 02:47 PM   #5
sandiego65
sandiego65's Avatar
Napa has them
sandiego65 is offline   Reply With Quote
Old 10-28-2012, 10:11 PM   #6
eldogg
eldogg's Avatar
Look in the Help section of your local parts store. The family owned store (Complete Auto Parts) I buy from has them in stock in their Help section.
eldogg is offline   Reply With Quote
Old 10-29-2012, 11:13 AM   #7
lil_sahara450r
thanks guys! went to napa and picked em up just now.
Old 10-29-2012, 02:25 PM   #8
Pro Performance
Nice... I didn't know Napa had them. Good information to know.
Old 10-29-2012, 10:15 PM   #9
Snowbound
Snowbound's Avatar
I have never seen or heard of a failure on one of these. Is it worth upgrading my '65 U bolts? Mine show no rust or damage.
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 10-30-2012, 01:41 AM   #10
sandiego65
sandiego65's Avatar
They look good have a nice zinc plating on them and come with lock nuts for 7 bucks I think it's a decent investment, makes the undercarriage look pretty.
Old 10-30-2012, 08:53 AM   #11
lil_sahara450r
It's more of a safety precaution then anything. The 60-66 u bolts are thin and weak looking when you compare them to the 73-87 style. When you see them side by side you will see the huge difference. Most failures luckily don't happen while going down the highway, it happens when you are backing up and have the wheel turned. Most of the time it is on a lowered truck. There have been a few threads about it in the past, I will try to find em.
Old 10-30-2012, 08:55 AM   #12
lil_sahara450r
http://67-72chevytrucks.com/vboard/s...d.php?t=543800
Here's one
Old 10-30-2012, 10:45 AM   #13
SCOTI
SCOTI's Avatar
When the brake systems were upgraded to discs, the u-bolt size was increased. The smaller ones will work on a drum or disc truck, but the larger diameter units would be better.
The later model x-member u-bolt holes are sized accordingly. The earlier trucks will require some clearancing to use the larger diameter units.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-30-2012, 10:48 AM   #14
lil_sahara450r
Yes, just need to drill out the original holes to 9/16 I believe. And use NEW steel lock nuts
Old 10-30-2012, 02:23 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Just bought all four under twenty bux shipped from NAPA.com to my front door. U-bolts and nuts look good, but I had to grab washers from Lowe's...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-02-2012, 11:02 PM   #16
richards72chevy
richards72chevy's Avatar
Should thread lock or anti sieze be applied to the threads?
richards72chevy is offline   Reply With Quote
Old 11-03-2012, 01:14 AM   #17
lil_sahara450r
I'm not sure.. What came with my kit from napa had grade 8 lock nuts with it. Maybe someone with some a lot of suspension experience will chime in on that question
Old 11-03-2012, 09:05 AM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
If not using lock nuts, I would use red thread locker to be safe
-Chris
