Old 10-26-2012, 10:46 PM   #1
superwade57
factory posi
i have an 86 c10 it has a gov-loc posi, its missing some clutch disks so im looking for a better factor posi to replace it... so what fits? the the earlier 10 bolt 8.5 28 spline "S spring" type out of camaros work? or what will interchange? just talking carrier in my stock housing.
superwade57 is offline   Reply With Quote
Old 10-26-2012, 11:47 PM   #2
Firebirdjones
Re: factory posi
Any of the 28 spline 8.5" posi carriers will work from 71 on up, so long as you grab one that is the same series as yours (aka: 3 series/4 series gear ratios)
Right around 1988 GM switched the 8.5" rear to a 30 spline axle. So basically anything below that year range will drop in yours, which gives you a wide variety to search from, shouldn't be hard to find a good ole clutch style spring loaded posi.
Firebirdjones is offline   Reply With Quote
Old 10-27-2012, 10:03 AM   #3
superwade57
Re: factory posi
how do i know what series i have... it has 2.73 on the spid and 3.73 in it now thats series 3 right? and what are the series denotions?
Old 10-27-2012, 10:36 AM   #4
Firebirdjones
Re: factory posi
On the 8.5's the carrier breaks are 2.56 or taller gear. Or 2.73 and shorter gear.
If you find anything with 2.73 (which is very common) or shorter, it will work with your 3.73's. So anything with 2.73/3.08/3.42 etc...
Old 10-27-2012, 12:41 PM   #5
ont_guy_38
ont_guy_38's Avatar
Re: factory posi
Have a camaro one in mine and I'm very pleased with it
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
