Old 10-27-2012, 09:56 AM   #1
sixty7swb
67 1/2 ton frontend to frame question.
I've got a 67 1/2 ton chevy frame and i want to put a later model 5 lug disc break frontend under it. Will any other year besides 71 and 72 fit under my frame? Thanks.
sixty7swb is offline   Reply With Quote
Old 10-27-2012, 10:33 AM   #2
JohnT71
Re: 67 1/2 ton frontend to frame question.
Put a 86 frontend on my 68 had to drill one hole on each side of the frame.
"There's a force in the universe that makes things happen; all you have to do is get in touch with it. Stop thinking, let things happen, and be the ball." -Ty Webb
JohnT71 is offline   Reply With Quote
Old 10-27-2012, 11:22 AM   #3
chopnchaneled
chopnchaneled's Avatar
Think he's talking about front suspension.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 10-27-2012, 12:33 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
You can use 71 up to 86ish, as those years have the thicker disc rotor and in 87 they get thinner. Keep in mind that the what year you go with, try to keep it all that year due to sizes of the tie rod and ball joint shaft sizeds So you can keep your upper/lower A-arms, but go with the later year ball joints.
Or you can do the whole engine/suspension crossmember swap. Do a search on here as lots of us have done these swaps.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 10-27-2012, 10:48 PM   #5
sixty7swb
I have an 85 parts truck can i just bolt the whole front 85 suspension to my 67 frame?
