Old 10-27-2012, 10:15 AM   #1
54belair
54belair's Avatar
Changing Pinion Angle
I have fought pinion angle changes on other cars Ive built.
My question is-- how much change have you noticed(on pinion angle) and how thick of a shim have you used on a 3" to 4" rear drop on the coil spring trucks. Is it easier to fab. your own spacers or do the aftermarket spacers work?
I see alot of discussion on suspension drops but not much said about adjusting the pinion angle.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 10-27-2012, 12:37 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Changing Pinion Angle
Good question! I'm waiting for an answer as well.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-27-2012, 02:49 PM   #3
54belair
54belair's Avatar
When I bought the truck, it had been driven for 1 or 2 years in its present configuration, which was supposedly a 3" drop in the rear by heating the springs (?) It was lower but I never measured because I knew it was all comming apart anyway. I drove it very little before I took it apart and didnt detect any vibration--but there are no shims for pinion angle either. surely if it is an issue, someone here will have worked on it.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 10-27-2012, 03:17 PM   #4
pat 70/71
pat 70/71's Avatar
If I'm not mistaken, our trucks with the calculated load (maximum live load) is @ 5" of drop on the rear end witch puts the drive line/ pinion in line. I remember some one telling me this years ago and not sure of its validity so please don't use this information without checking this theory out for your self. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-28-2012, 11:19 AM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
You can flip the control arm mounts on the crossmember.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
