Old 10-27-2012, 04:30 PM   #1
cubber
Another Wheel Question
Ok, so I have spent several days searching, and have learned a lot about wheel and tire fitment on these trucks. I have a 69 STEPSIDE on 72 suspension (front and rear) I will be installing air ride and McGaughy's 2.5" drop spindles. I have a brand new set of wheels and tires that I bought for a truck I sold, and would really like to use them. They are Ion Alloy 15x8's with BFG 255/70r15 radial tires. The wheel backspace is 3 and 7/16". Lolife showed me a pic of a SLICK blazer with 7" rallys, and the tires tucked the way I want mine to. I know the 7" rallys have 3 and 5/8" backspace. I guess this would mean that the outer edge was 1" farther out? I have driven my truck with a 2/4 static drop, and had no issues, but I wonder how the new spindles and bags will change the geometry, and if the wheels will tuck in the fenders so I can set it down. I cant measure because i am waiting on my Porter built front end kit an c notch before i do a mock-up. Just wondering if this wheel and tire combo could work, and if I will have to clearance anything. Sorry for writing a book, I just thought it would help to give all the info I have so far. Thanks soooo much.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 10-27-2012, 05:54 PM   #2
cubber
Re: Another Wheel Question
What about these, with a 215/70r15 whitewall?
http://www.summitracing.com/parts/wv...2278/overview/
=MATTHEW
Old 10-28-2012, 09:13 AM   #3
502ms
502ms's Avatar
The rears won't fit with that backspacing. Mine are 15x8, 4.25 backspacing, and they are flush when aired out. I trimmed the inner fender in the rears just to make sure I had no issues when rolling
The fronts tuck fine...if going wider, you need to trim fender skin...to lay flat, remove inner fenders and get slosh tubz
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-29-2012, 07:03 PM   #4
cubber
Thanks, Leon. I bought these wheels and tires for a truck I sold, and I am just trying to figure out if I can use em. I'm in no hurry to buy new ones, but if i have to, I need to plan my budget a little differently. What size tires do you run, and how much clearance do you have? Did you have to trim your LCA's?
BTW, cool youtube vid.
=MATTHEW
Old 10-31-2012, 08:39 PM   #5
502ms
502ms's Avatar
Thanks so much, Cubber!
I am running 215/60/15. I have plenty of room to ride low (about 1" off the ground and tucking). No trimming of uca/lca
Best Regards,
Leon M.
Old 11-01-2012, 09:32 PM   #6
cubber
Are you running drop spindles? I have heard that they cause a clearance issue on the LCa's and people say to trim it, but that makes me a little nervous.
=MATTHEW
Old 11-02-2012, 03:33 AM   #7
502ms
502ms's Avatar
If I recall, it's a 2.5" drop spindles
Best Regards,
Leon M.
Old 11-03-2012, 10:17 PM   #8
cubber
Cool, man. I have a new set of drop spindles to put on. Thanks for all your help!
=MATTHEW
Old 11-03-2012, 11:12 PM   #9
502ms
502ms's Avatar
Anytime! Keep us posted!
Best Regards,
Leon M.
Old 11-05-2012, 12:13 AM   #10
cubber
For sure. I have my shop full of parts from Porterbuilt, Brothers, and AZ ProPerformance, I need some time so I can get crackin' and have some updates for my build thread.
=MATTHEW
