![]() Join Date: Jul 2012
Camper Mirrors
I have seen some camper mirrors that have four screws in the back and the arm attaching to the side. I have seen others with rivets in the back and the arm attaching to the back of the mirror. Which one is the factory style?
All Day Every Day '72 C20 Cheyenne Custom Camper http://67-72chevytrucks.com/vboard/s...d.php?t=549132 |
"Ochre Ogre"
Re: Camper Mirrors
if the mirror elbow attaches to the outside of the mirror head it is correct for the below eye line mirrors for 69-72. If the elbow attaches inside the mirror head it is a next generation truck mirror.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Re: Camper Mirrors
When you say "next generation", are you talking about '73 and up?
"Ochre Ogre"
Re: Camper Mirrors
Yes, next gen is 73 and up. I am not sure when they officially changed over to that style. There could be some overlap of mirrors. But the external elbow with an acorn nut is correct for the 3 sizes of below eye-line mirrors.
There is also 2 styles of mirror heads out there that look like these as well. One style has the brackets on the back of the head centered top to bottom and left to right. Those are GM correct as I know it. The other mirror head is centered left to right but maybe an inch off center top to bottom. I have seen them as replacement mirrors and I have seen them on Ford trucks from back then as well.
#5 | |
![]() Join Date: May 2010
Re: Camper Mirrors
My 69 with the smaller style "W/C MIRRORS-JR" below eyeline mirrors came new with the bracket offset toward the bottom (or top, if mounted that way). I have always assumed the first year or two (69 and possibly 70 unless mine was a freak) were that way and the later model years through 72 were centered. Also, the Dodge trucks and Ramchargers from the early 70s as well as the GM vans through about 79 used the exact same mirror heads with the bracket centered if the below eyeline style mirrors were ordered. The reproductions of these mirror heads aren't close to correct. |
