build thread 1995 gmc yukon
I bought this truck to give it a paint job and put a 400 in it because it is knocking right now.
the interior is nice but missing a few pieces and the body needs to be straightened out and painted it is pretty much rust free except for one spot that seems to have rusted from the outside because of some running boards that were installed on the truck it needs just little touches here and there but I want a boat and I think that this would pull really nice with a 400 in her |
Re: build thread 1995 gmc yukon
today I took the crank and rods out of the block and decided that I did not like the .003 clearance that was in one of the rod bearings so I am gonna have the crank miked and probably ground 10 over on the rods and 30 over on the mains
found out that the crank was 30 over on the rods and had standard sized bearings. it would have knocked like a woodpecker if I would have used the block without sending it to the machine shop
I got off easy with this motor. all I had to buy was a re-ring kit and a cam kit. the cam I am using is an rv cam 420 intake 443 exhaust. the cank did not need to be ground and the cylinders honed out and did not need to be bored the specs on the block and crank are the block is 30 over making it a 406. the crank is 30 under on the rods bearings and 20 under on the mains here are some pics of the crank, cam and block as I start to put it together |
just got done platicgauging the mains on the crank and its .002 across each main so I got great oil clearances in the mains
Nice start/project...i have the chrome version of those wheels, which I hate because they're pitted bad. What a pita to sand them down, but they're now matte and look pretty good. Not a fan of the tails, what color are you going with?
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
I am gonna go with the original color of the truck because I dont want to paint the door jambs or the roof. I am thinking of adding pearl to the light blue and doing the dark blue in black covered with a translucent dark blue pearl.
I am gonna paint the front grill dk blue and the mirrors I kind of want to do dk blue racing stripes across a cowl hood |
Sounds good. I know about the pain of the roof and jambs, went from gold to black was a nightmare. I have a high respect for bodymen now, lol.
just got the shortblock done
got the old motor out this weekend
here are a few pics of the motor and then one of the motor just after I got it stuck down in there
Countdown Survivor
Are you running TBI on a 400? Is that an aftermarket manifold? Looks good so far
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
well I have it running and have all the leaks taken care of. I am in the process of draining all the fluids and I found that a u joint in the rear end had come apart and took a chunk out of the yoke. the previous owner beat the driveshaft into submission so needless to say I put a used driveshaft and yoke in it with new u joints
#13 |
Are you using the heads off your 350 on the 400? Any trouble with the steam holes?
I had a 400 in my truck with Edelbrock RPM heads and it has never ran better than with that motor.I had a carburetor on it so I could run a cam and it really woke that truck up. I then put a 290 hp 350 in it and when this engine wears out I am going back to a 400. Lynn |
| Bookmarks |
