Old 10-28-2012, 07:08 PM   #1
RustyHunk-O-JunkGuy
anybody use chevelle exhaust kit?
Quick and easy exhaust question, actually two.
1. Anybody use a kit for the A body on there 2wd with any luck? Want to do 2 1/2" kit on the Burb, but the lack of kits out there for these trucks is lame. How easy was yours? Have to modify much? I'm running mid-lengths, a H-pipe and Cherry Bombs so I was planning on some mods, but wondering ho close the axle bends were.
2. Any have any luck with "header buddies", those belled flange jobs for the collector connection. I've only ever used the old three bolt flanges and gaskets. Ya, constantly fighting the exhaust leaks gets old fast.
Thanks guys
RustyHunk-O-JunkGuy is offline   Reply With Quote
Old 10-28-2012, 07:12 PM   #2
vectorit
What?
vectorit's Avatar
Re: anybody use chevelle exhaust kit?
If I were you, I would just take it to a local muffler shop and have them set you up with a nice system made to your liking.
Oh, and get rid of the headers and put the OE exhaust manifolds in again.
Headers are more trouble than what they are worth.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-28-2012, 07:51 PM   #3
RustyHunk-O-JunkGuy
All the muffler shops around here to crappy work or you have to pay to much for a higher end shop, which I'm not down for. I've got no problem with the fab work, that's what I do for a living anyway. I just was wondering mainly about the bends around the axle/springs/shock mounts.
Old 10-30-2012, 10:00 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
I've had good luck with the Flowmaster DIY mandrel bent kits. Takes some fab work, but the finished product is worth the effort.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-30-2012, 04:33 PM   #5
Street Smart
Street Smart's Avatar
The flowmaster kits use heavy, coated pipes and really last.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 10-30-2012, 07:43 PM   #6
Kevin McPherson
Kevin McPherson's Avatar
I have had better luck getting 3 bolt flanges to seal with a steel donut gasket.just make sure the gasket doesnt fit into the pipe
Kevin McPherson is offline   Reply With Quote
Old 11-01-2012, 01:05 AM   #7
RustyHunk-O-JunkGuy
Checked the Flowmaster kit on Summit, it lists as 16 ga. tube. LMC sells a kit but it comes in 2 1/4" only, also listed as 16 ga. with glass packs and no H-pipe for $189.95. Summit wants $260 for the 2 1/4" kit and $280 for the 2 1/2".
Anybody ever use the LMC kit? I'd would probably be swapping out the glass pack for some Cherry Bombs anyway so I'm not to worried about the mufflers that come with it.
Old 12-28-2012, 02:03 PM   #8
notsolo
notsolo's Avatar
I used a 2 1/2" stainless Magnaflow kit for a Chevelle on my blazer. custom cut and fit... added a few extra clamps custom made hangers ..Cost about $585 delivered
notsolo is offline   Reply With Quote
Old 01-01-2013, 03:29 PM   #9
RustyHunk-O-JunkGuy
How were those axle bends?
Old 01-04-2013, 07:05 PM   #10
notsolo
notsolo's Avatar
I thought it was good...I can get you a photo from the bottom side if you like..the only shot I have of the rear is distant.. shocks are green...urethane hanger bushings red.
Old 01-07-2013, 12:45 AM   #11
RustyHunk-O-JunkGuy
Looks good! I figured there had to be a fair amount of clearance on those kits if they are designed to clear the upper links on an A body.
