10-28-2012, 08:23 PM | #1 |
Does Anyone Have One Of These?
10-28-2012, 08:33 PM | #2 |
Re: Does Anyone Have One Of These?
That is pretty cool if they can back up there info, wonder if it will work with transmissions too. If so, someone might save a lot of time and money by testing the oil of a used car prior to buying.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
10-28-2012, 09:41 PM | #3 |
Old member
It says they are not shipping yet. Oct -Nov time frame. I saved it to favorites so I can check back. I'll try one for the $40.00.
10-29-2012, 12:39 PM | #4 |
That's pretty cool.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-29-2012, 03:10 PM | #5 |
Always wondered if I realy needed to change oil as its glugging out of the drain hole looking as clear as it did the day I put it in. I just went by the old standard 3/3
10-29-2012, 06:53 PM | #6 | |
I am a Referee of life.
I woudn't think it would matter on a used car unless you were getting it from an individual.most stealerships change the oil before they ever hit the lot.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-29-2012, 07:24 PM | #7 |
Quit if it's not FUN!!!
I had a Thermodynamics professor in college who had a '56 Chevy wagon 6 cyl strt. drive that he purchased new in 1956. At the time, (1965) it had 175k miles and had never had an oil change. He religiously changed the top mounted filter every 1000 miles, topped off the oil and drove it everyday. It purred like a kitten and showed no signs of problems. We were amazed! He preached that oil doesn't "wear out" it just gets dirty
. 'Course he also had an MGB with a full-on Stanley Steamer engine (but that's another story for another time.) |
10-29-2012, 07:53 PM | #8 |
Father of my best friend worked for Ma Bell(telephone) in the late 60's. He was in charge of a fleet operation. Said they never changed the oil. Only the filters. Then add some.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
10-29-2012, 08:22 PM | #9 | |
Posted via Mobile Device |
10-29-2012, 09:32 PM | #10 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
"WaveOn Technologies introduces the first reusable consumer model motor oil tester" I used one in a fleet diesel truck shop 34 years ago! I dont remember who made it but it looked just about like the one shown. In the center of a half dollar sized plastic valley was a 3/8" dia. flat metallic surface that had an inner and outer ring. You would place a couple of drops of oil off the dip stick on the metal surface and a needle gauge much like an analog volt meter would indicate good to bad or green to red. Im sure it was either a resistance meter or perhaps a volt meter because when I (I'm a curious sort) touched a paper clip to the inner and outer metallic surfaces, the needle immediately jumped to the red witch indicated "Change" ...Clean oil barely moved the needle, black dirty oil is apparently conductive and would move the needle into the red zone. Thats not new technology. "just sayin" ;-)
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
