Old 10-28-2012, 09:46 PM   #1
mattpiotr
Cracked Flywheel???
Well driving home today and when i pulled in the driveway i head a pinging noise, a noise that i heard once before and i knew exactly what it was, the fly wheel cracked. i had the same problem 4 months ago back in June and i changed it out with a Napa 168tooth one. I plan on going to Napa and getting another one since it is under warranty but this time im going to upgrade to the Heavy Duty Fly Wheel. I was wondering what caused it to crack if there is something i should look at when i pull the transmission back to switch it?
mattpiotr is offline   Reply With Quote
Old 10-28-2012, 09:50 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Cracked Flywheel???
Flex plate or flywheel? Some get this confused if you crack a flywheel it's A. Garbage to begin with B. race car or c. You shift like dirt.
Flexplates can break in a lot of ways though
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-28-2012, 10:08 PM   #3
mattpiotr
i believe a flexplate?. its on a automatic turbo 400, i know one is for manual and the other auot,
Old 10-28-2012, 10:48 PM   #4
INSIDIOUS '86
Flexplate. If the trans isn't centered quite right the flex plate will do a wavy bacon kinda thing at rpm as a result and will stress fracture. Plus I'm sure the napa flywheels aren't to great as well. Try looking at sfi spec flywheels
Old 10-29-2012, 02:54 AM   #5
andrewmp6
A flexplate is a auto a flywheel is a stick but everyone calls a flexplate a flywheel tho.I would order a better one from like summit and make sure you put it in right should last a long time.
andrewmp6 is offline   Reply With Quote
