Old 05-31-2003, 11:55 PM   #1
bigjimzlll
bigjimzlll's Avatar
Unhappy Time for a new engine
Well I broke something...It was after a good pass..Not sure what happened. I have good oil pressure..good water temp. The timing ended up 12 degrees retarded after the run..skipped a tooth??..what every happened I believe its terminal..no water in the oil or vis versa...but a ton of blow by...probably broke a ring or piston(was running a small shot of N20) Rockers are really clacking too...Hmmmm no broke push rods or springs that I could tell..It runs ok now, but I know I hurt it bad..Oh well...chit happens
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-01-2003, 12:02 AM   #2
GMC71k20
are you going to re-incarnate the setup you have now or build something beefier?
GMC71k20 is offline   Reply With Quote
Old 06-01-2003, 12:04 AM   #3
bigjimzlll
bigjimzlll's Avatar
oh...much bigger..lol I probably will go 388, unless I can find a 400 block real quick
Anderson,CA
