Old 10-29-2012, 10:41 AM   #1
MDc10
MDc10's Avatar
Loose steering
Here's the deal, I recently replaced my steering box on my 86 shortwide. It leaked like a sob, the steering was also loose as a goose. So I assumed change the box would take care of my loose steering, wrong. So I changed my tie rod ends, inners and outers. Still loose. When I say loose, what I mean is when im driving straight down the road and can turn my steering to the left and to the right and my truck doesn't move. And im not talking about moving it a little, damn near a quarter turn. Loose steering right? Does anyone else have this problem? Does the sway bar need to be changed, is there another way to "tighten" the steering, or have I overlooked something? Would appreciate you guys help on the subject. Thanks in advance.
Mike
MDc10 is offline   Reply With Quote
Old 10-29-2012, 11:20 AM   #2
JTautomotive
Re: Loose steering
Mike
The steering in my 1980 k10 was remarkably loose just as you described yours, the ragjoint the connects the steering shaft to the box was the culprit for me. i would check the ragjoint out first
1980 K10 350/SM465
JTautomotive is offline   Reply With Quote
Old 10-29-2012, 11:20 AM   #3
75chev4x4
75chev4x4's Avatar
Re: Loose steering
Was this a new box or a used box you put in?
75chev4x4 is offline   Reply With Quote
Old 10-29-2012, 11:34 AM   #4
JoeyBones
Re: Loose steering
From reading around and looking at mine, the rag joint is my first item on the list to change. Check out the Jeep XJ steering shaft modification. If you can find one of those locally in good shape that would be a pretty good upgrade. You can also order a u-joint shaft from summit or the like, but they get pricey quick.
JoeyBones is offline   Reply With Quote
Old 10-29-2012, 11:45 AM   #5
MDc10
MDc10's Avatar
Re: Loose steering
changed it when I changed it the steering box.
Old 10-29-2012, 11:47 AM   #6
MDc10
MDc10's Avatar
Re: Loose steering
It was a new box.
Old 10-29-2012, 12:37 PM   #7
75chev4x4
75chev4x4's Avatar
Re: Loose steering
How does the frame look around your box?
Old 10-29-2012, 12:41 PM   #8
MDc10
MDc10's Avatar
Re: Loose steering
I can't see it at tue moment. But when I changed the box I didn't notice and out of the ordinary, everything looked good. Why do you ask?
Old 10-29-2012, 12:55 PM   #9
JoeyBones
Re: Loose steering
have you tried making any adjustments ON the box?
Old 10-29-2012, 01:20 PM   #10
MDc10
MDc10's Avatar
Re: Loose steering
That I haven't don't yet. How exactly do I do that?
Old 10-29-2012, 01:23 PM   #11
JoeyBones
Re: Loose steering
Check that video...should help
Old 10-29-2012, 02:23 PM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Loose steering
That adjustment doesn't work on worn boxes FYI. When you tighten that the slop can go away but the more you turn from the left or right of center it start getting hard. Why? Because the worm that that adjust doesn't wear evenly.
Is this a "rebuilt" box from the parts store? The consensus on those is that they are leak free shiny versions of what you already have and don't solve anything. Try firm feel, flaming river, agr or summit and get a box that is FIXED not reconditioned
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-29-2012, 03:52 PM   #13
Skunksmash
Skunksmash's Avatar
Re: Loose steering
Also check your idler arm, and you pitman arm. Gotta get to the steering on my own truck for this reason. When I replaced my pitman arm, it took about 1.5" of play out of the wheel. A big improvement. Now only 3 inches left to go lol.
Skunksmash is offline   Reply With Quote
Old 10-29-2012, 04:26 PM   #14
Skunksmash
Skunksmash's Avatar
Re: Loose steering
I checked around at those you listed insid, and it looks like only AGR sells them for these trucks. Summit racing just sells the autozone stuff, Firm feel is for mopar, and flaming river doesn't sell them for the later models. Agr has them though, but they're pretty pricey. 300-400 dollars. Is there anything wrong with the ACdelco brand ones? Seems like they'd have to be up to GM's specs.
