Old 10-29-2012, 02:16 PM   #1
Shooters_7
Air Suspension
For those of you running an air suspension, did you go with hard lines or soft and if so where did you purchase them at? Issues with installing and or bending? Size lines? Any regrets or things you change?
I'm fixing to have to get line run on my truck and this is the first air suspension I've done. I've looked at a couple of builds so far but not a whole lot of info on air lines. One build ran stainless for his air lines.
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
Old 10-29-2012, 02:38 PM   #2
kieth
kieth's Avatar
Re: Air Suspension
DOT plastic airline is easy to work with and lots of connectors are available for use with it. If it is good enough to go a million miles on a tractor trailer its good enough for my 66............Kieth
kieth is offline   Reply With Quote
Old 10-30-2012, 08:42 AM   #3
Shooters_7
Re: Air Suspension
Thanks, I really didn't feel like bending line for an air setup. I know I can buy this stuff in rolls in multiple sizes. Looking at going with 3/8 right now as I'm not doing anything crazy.
Conner
Old 10-30-2012, 11:23 AM   #4
jimmydean
jimmydean's Avatar
Re: Air Suspension
I used DOT air line and press fittings with only a few leaks the first time (soapy water in a spray bottle, took about an hour to fix the leaks). I am doing hard line this time because I have nothing better to do.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-02-2012, 10:45 AM   #5
scot 6 feet eleven
scot 6 feet eleven's Avatar
Re: Air Suspension
i used plastic too , easy peasey
1960 chevy 4.6 police interceptor chassis under this bad boy with 24 inch lexani's
scot 6 feet eleven is offline   Reply With Quote
Old 11-03-2012, 12:28 AM   #6
shortbed70
shortbed70's Avatar
Re: Air Suspension
Plastic here also. Use ptc (push to connect) fittings! Don't waste your time with compressions unless you want problems later... Plus every time you take your line out o the fitting with compressions you have to cut a chunk o line off and get a new sleeve.... Just sayin
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-03-2012, 10:49 AM   #7
lownslw64
lownslw64's Avatar
Re: Air Suspension
i did mine in stainless steel tubing. probably not the most cost effecient but you will never have any problems with it at all.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 11-03-2012, 06:39 PM   #8
Shooters_7
Re: Air Suspension
Love the stainless but I've never bent that before and its been fifteen years since I've bent brake lines. Anyone got any good diagrams or where did you learn how to run stuff? First time and I'm trying to do it right! Thanks
Conner
Old 11-03-2012, 06:47 PM   #9
Shooters_7
Re: Air Suspension
Send me more pics as I'd like to see how your lines are ran. Thanks
Conner
Old 11-03-2012, 07:05 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Air Suspension
You have great tube bending skills!
Beautiful work.
Keith
Convert to disc brakes.
Old 11-03-2012, 10:54 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Air Suspension
Those lines are killer.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-16-2013, 12:39 PM   #12
rmvlt1100
rmvlt1100's Avatar
Re: Air Suspension
That systems is outstanding. Can you tell me what fittings you used? They don't look like normal AN fittings. And also what size tubing you used?
Thanks and again that's a nice setup,
Robert
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
