Old 10-29-2012, 04:10 PM   #1
heathbirkendahl
70's 350 to Vortec style 350
Who has gone from a 70's 350 to a the new Vortec style 350? I need to know how much fab work was involved?
Questions:
1. Are the motor mounts the same?
2. Did it bolt right up to your 350 trans
3. Will my headers work on the new heads?
Any other guidance or pointers would be greatly appreciated.
Thank you,
Heath
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 10-29-2012, 04:26 PM   #2
MARKDTN
Re: 70's 350 to Vortec style 350
I have not done it but yes to all 3 questions. The motor mounts and transmission pattern is exactly the same. The exhaust pattern is the same, but the ports are shaped a little differently. Depending on the header it should be fine. The biggest difference is the intake bolt pattern. You will definitely need a Vortec pattern intake.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-29-2012, 04:49 PM   #3
heathbirkendahl
The motor I'm buying has an intake some I'm covered there. My main concern was motor mount positioning. Sounds like a straight forward swap. I'm just trying to flush out any GOTCHAS!!! I hate gotchas!!
Old 10-29-2012, 04:50 PM   #4
70CHEVYBB
70CHEVYBB's Avatar
Here is a 96 350 with edelbrock intake and in my 70 lwb. I have changed my mind and am installing a 468 bb now. I then too kthe 96 and installed it in my 72. runs sweet too.
70CHEVYBB is offline   Reply With Quote
Old 10-29-2012, 05:27 PM   #5
heathbirkendahl
Very nice! I'm looking the complete 330 Horse 380 Torque GM crate engine.
Old 10-29-2012, 06:20 PM   #6
69gmcc10
69gmcc10's Avatar
I am currently doing this project, almost done.
Are you running the fuel injection or going carb?
I pulled to old one out, boulted up to the th400 and back in the hole in a day (I took off the hood and fenders).
Everything bolted up like the old one, my advice is replace all of the mounts with prothane mounts (energy suspension is developeing theres and are not avalable yet) and leave all of the mounts loose so you can get that 1 bolt that bolts in from the bottom.
Things that have held me up were miscelanious, fuel line not sealing to the pump, old temp sender wont fit in the head and new temp sender has the wrong resistance, ordering the bronze dist gear, finding a waterneck to go over the temp sender.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-29-2012, 07:23 PM   #7
GMCJOE
GMCJOE's Avatar
Very nice, easy way to go serpentine also. I am going to get me one of these vortec 350's cheap and start building it over time. Save it for a future 67-72 purchase.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-29-2012, 07:57 PM   #8
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Or just do like I am and convert your original 350 to a vortec by changing the heads and upgrading to a roller cam.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 10-29-2012, 08:24 PM   #9
GMCJOE
GMCJOE's Avatar
Yeah, I don't have an old one to do that with. Them Vortec 350's are a dime a dozen and sell pretty cheap on C/L. Plus it wouldn't be going in anything anytime soon. I got a 96LT1 corvette motor in my 69 right now. Just a plan for a future truck for me. I want the engine before I get the truck. That how the LT1 found its way in to the 69...lol Going roller on a older motor isn't in my budget when I do things...lol
Joseph
Joe's 69 GMC
Old 10-30-2012, 01:47 PM   #10
Vintage Windmills
Vintage 4x4s
Makes sense. It was def more costly to convert mine but Iwanted to keep the truck with correct engine for originality. I would def take the route you are if Iwasnt after the origanal aspect. Sorry for grammar on my phone now
Old 10-30-2012, 07:29 PM   #11
Daves70
Daves70's Avatar
The only thing I see is if you use a carb you will need a electric fuel pump.The vortec motors are not machined for a mechanical pump but should be a straight swap other wise.I bet it will work great.
Daves70 is offline   Reply With Quote
Old 10-30-2012, 10:53 PM   #12
70CHEVYBB
70CHEVYBB's Avatar
I used a delpi puimp from oreilly's(44.00 bucks). I mounted it on the right side of the frame. super quiet and works great.
Old 10-30-2012, 11:35 PM   #13
FirstOwner69
FirstOwner69's Avatar
Is this the GMPP crate engine? If so, is the the one with or without the serpentine setup?
I am putting the 330 HP Deluxe, the one complete except for the serpentine (since I want to retain the original appearance), in my 69. The engine does accept a mechanical fuel pump in the normal place. I had a forum member machine an original temp sender to fit in the left head. I also found a pre-bent hard fuel line from the pump to carb that fit with some very minor tweaking and is period correct. I think it's the one made by The Right Stuff for the Holley equipped 1968 Camaro Z-28. If interested I can check and confirm. I have the original A/C system, and the brackets presented a challenge since the rear and top braces did not fit the Vortec head design. I had to fab those. Everything else bolted right up.
DISCLAIMER... I have not yet started the engine. I should get the painted cab mounted in a couple weeks.
FirstOwner69 is offline   Reply With Quote
Old 10-30-2012, 11:47 PM   #14
heathbirkendahl
It turns out I'm going to keep the older style motor. I'm having headers put on andr they are for non-D Port heads. Headers were $425 bucks. So, I'm not replacing them again. Blue Print motor from JEGS or from GM is the plan.
