Old 10-29-2012, 07:51 PM   #1
Corts60
Just here to tinker
Corts60's Avatar
Will an '84 10 bolt swap in place of '78 12 bolt?
The ONLY reason I am going to a weaker axle is because my rear end is about to grenade and I don't have the money right now to do it right. I found an '84 parts truck that has a 10 bolt for $150. So will this be a direct swap to my '78?
I need help ASAP, so thanks in advance!
-Cort
Old 10-29-2012, 08:16 PM   #2
GM-power
GM-power's Avatar
Re: Will an '84 10 bolt swap in place of '78 12 bolt?
It should swap in no problems.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 10-29-2012, 08:39 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Nice! That's what I wanted to hear, thanks!
Old 10-29-2012, 09:10 PM   #4
J Knight
J Knight's Avatar
You will probably need to swap the yoke on the rear or get conversion u-joints, and the e-brake cables on 84 and up are run to left side only.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-30-2012, 12:27 AM   #5
Corts60
Just here to tinker
Corts60's Avatar
What is a conversion u joint? If I swap the yoke, won't that mess up the crush sleeve pre-load or something? What is the difference in the yokes?
Old 10-30-2012, 02:02 AM   #6
andrewmp6
A conversion u joint is a u joint that has two different sizes on it where a normal one is the same size on both sides.
andrewmp6 is offline   Reply With Quote
Old 10-30-2012, 07:05 AM   #7
ont_guy_38
ont_guy_38's Avatar
Ya the u joint is way easier...if you do a search on this site i'm sure you will find the number.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 10-30-2012, 10:24 AM   #8
Corts60
Just here to tinker
Corts60's Avatar
So if the Ebrake is on the left hand side, will I not be able to hook up my Ebrake? Also, the axle I found, the guy wants $150 for it. Is that a good price for a rearend?
