Old 10-30-2012, 01:21 AM   #1
fastcam1
Young gun
fastcam1's Avatar
Core support mount question
Quick question so anyone out there that has installed a 67/68 front clip on 69-72 frame what did you use for the core support mounts 67-68 style or the later? The reason I ask is the actual mount brackets on the frame have different size holes.
Any help would be great
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 10-30-2012, 08:53 AM   #2
steelhorse
steelhorse's Avatar
Re: Core support mount question
Doing the same so I want to know the answer also.
steelhorse is offline   Reply With Quote
Old 10-30-2012, 12:53 PM   #3
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Well i just went throuh this and the 69-72 are too tall and so are the 67-68 bushings. After stetting the body on the 72 4 wheel drive frame, even with shims between the body and rubber bushings i only had about 1/8 clearing under the core support and frame when the fenders lined up correctly with the cab body lines. So i just used a peice of rubber for the shim between the core support and frame. If any body else has any suggestions on why this is i would be happy to hear it, i thought it was because frame are a little different up front.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 10-30-2012, 01:03 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
67-68 core support mounts are a flat piece of rubber.
Not at all like the 69-72 mounts.
I would use a large fender washer to cover the frame bracket's larger hole,... and then use the correct 67-68 rubber washer.
Keith
Convert to disc brakes.
Old 10-30-2012, 02:20 PM   #5
Erl
Erl's Avatar
I used 69-72 mounts on my 68 GMC. I just increased the hole on the frame mounts. It worked great.
ERL
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
