10-30-2012, 05:18 PM | #1 |
1960-1966 Chevy Heavy Duty Headlight Harness's
This is our Heavy Duty Headlight Harness specifically designed for the 60-66 Chevrolet and GMC trucks. We have two model harness's for this body style, one for trucks equiped with single and another for trucks equiped with dual headlights. Our HD Headlight Harness's are the top of the line, and are constructed with quality materials. The Harness's are 100% "Plug n' Play" so there is no need to cut or splice any wires what so ever. They feature HD Ceramic H4 Headlight plugs, to ensure a long life and can handle very high wattage bulbs. The harness will work with any headlight set up that utilizes a H4 plug (eg. Sealed beam, Halogen, HID). With this harness installed, it will draw your power for your headlights directly from the battery (taking all the load off of your OE Headlight switch) and give your headlight the full 13.8V+ they need to run at 100% and give you a very large upgrade in light output!
------------------------------------------------------------- Below are a few of the benefits of upgrading your headlight Harness:
-------------------------------------------------------------------------- Price: $89.95 Single Headlight Model $99.95 Dual Headlight Model Shipping: $9.95 via USPS to the lower 48 States ONLY Shipping to Canada: $15.99 via USPS Payment: PayPal or a US Postal Money Order To Order: Simply send us a PM with your PayPal address AND the part number. Then we'll send you an invoice with a total via PayPal Part Numbers: Single Headlight Model: 6066HD812 Dual Headlight Model: 6066DHD812 ------------------------------------------------------------------------ Thanks for looking and have a great day! If you have a different year truck and would like a harness for it, please contact us and we will be happy to help! We have a harness for every year chevy truck from 1960 - 2007! And we will be introducing a harness for the 47-54's very soon! If you have any questions, please feel free to ask! MADE IN THE USA |
02-17-2013, 07:19 PM | #2 |
Re: 1960-1966 Chevy Heavy Duty Headlight Harness's
I bought one and they are NICE and easy to install. No problems.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
02-17-2013, 11:23 PM | #3 |
nice set up!! now i gotta sell some stuff to buy some more stuff George Carlin was right !!
02-27-2013, 12:09 PM | #4 |
Do you make the same harness for the stock headlights?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-01-2013, 08:18 PM | #5 |
I was wondering the same thing, I think? Stock appearance with relays?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
03-01-2013, 08:57 PM | #6 | |
You can use this harness with virtually any headlight set up you'd like. Whether it be stock headlights, or halogens etc. So this harness will work perfectly with stock headlights as well as upgraded headlights.
None the less, this is the only style of HD Harness that we make for the 60-66 Trucks. However, if you'd like some special configuration; we can also accommodate your needs for that as well! |
03-02-2013, 10:25 AM | #7 | |
03-07-2013, 08:29 PM | #8 | |
Any more questions please ask. Thanks |
08-29-2013, 05:41 PM | #9 |
Looking for a set of ground straps for my 66. I seen them on ebay, but you dont have any listed currently.
10-06-2013, 04:09 PM | #10 |
Any updates? Still looking for ground straps.
12-10-2013, 05:06 PM | #11 |
12-10-2013, 08:26 PM | #12 |
I would like a ground strap kit and a headlight harness. What would shipping be to 48144? Do you take PayPal?
12-11-2013, 05:02 PM | #13 |
12-11-2013, 06:02 PM | #14 |
But Found Her 25yrs Later!
Are you running any specials on these before year end?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-11-2013, 09:40 PM | #15 |
For the dual headlight set up, will these enable all four lamps when using high-beams?
Thanks, Scott |
12-11-2013, 10:12 PM | #16 | |
Yes sir, on trucks with the dual headlamp set up; our harness enables the "4-High" feature, so that all 4 headlamps are on when you have your high beams on. The high beam filament in each lamp in on when you have your highs on with our harness, so you have 4 actual high beams lighting up the night. If you have any other questions, please feel free to ask! Thanks, Baron |
12-15-2013, 01:08 PM | #17 | |
Bookmarking for when I get to that part of my re-wire. |
12-15-2013, 03:13 PM | #18 |
Any year end specials?
01-19-2014, 07:33 AM | #19 |
I paid almost a month ago and have not received my harness. Ive pm'd this guy several times, emailed him several times and even called the ph# that is available and no response to anything. Not sure what is up or what to do at this point.
01-19-2014, 09:36 AM | #20 | |
01-19-2014, 11:37 AM | #21 |
Rideblue
I have one of these harnesses and am more than happy with the quality of the product and the ease of installation. I can't speak to the ordering/communication problem you are having but the product is great. Hope you get it worked out.
01-19-2014, 07:03 PM | #22 | |
pm a mod for help in reaching out to them
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-23-2014, 08:07 AM | #23 |
Still no resolution of this issue. I may be out $127. My next step is to try and retract my payment from PayPaypal.
02-18-2014, 02:07 AM | #24 |
Man i think i just messed up,, should of read farther tried to order by PM and his box was full ,,so found him on ebay and ordered the dual kit ,after reading these i looked at the feedback on ebay and found 4 neg out of 1200 sales which is not bad but three negatives were in the last month ? hopefully my karma will see this thru and hopefully coach works has gotten it together ,does anybody know of other companies that offer his kit ? hate to have to make my own,, know time thx and good luck to us both lol
02-18-2014, 09:50 AM | #25 |
Yeah he has been booted off this board from what Liz has told me. Nothing against you, but if you get yours, I will be very upset as he has taken my money and no items shipped to me! There has been a thread i started in the vender review section. Some people got their stuff others didnt.
