Old 10-30-2012, 11:07 PM   #1
truckmanloco
Buddy Buckets all the problems and the fixes.
So over the past few years with the gaining popularity of these seats and there ridiculous price... I came up with solutions to alot of the common problems (shortfalls) of the seats as far as convenience. Also too kind of remedy the steep prices of the small pieces that are commonly broken or wore out. Also the steps to the " popular folding or tilting seats. In all actuality they are the same seats just one year of big DOT safety mandates brought about the change. So here are the changes and the instructions to do these mods. Hope this helps somebody.
First of all the cab support bracket price between 25-60 dollars... remedy.
Redrill the four holes holding the C- clamps forward shifting the buddy seat back. This will rest the back of the seat firmly against the cab which looks ten times better. And if you say it will rub off the paint every bench/ bucket seat rest against the cab.
Then the buddy seat clamps that hold the seat agaist the frame and in place....cost between 25-60 dollars. Remedy....
Conduit straps.. available at any home improvement/ Electrical supply stores. Price about 5 bucks for all four and a little black paint. And seriously who would crawl under your seat to inspect.
http://www.elecdirect.com/catalog/bf...f6148ffc7.aspx
Sliders self explanatory, Price up to 150 dollars and rising.
The originals are hard to find when you do someone will try to bend you over for the price. Remedy... any universal slider and alot of power sliders work. Remedy.... heres one example-
http://www.speedwaymotors.com/Univer...ders,7103.html
Price 25 dollars.
And then the folding or tilting seats. All early 67 seats fold forward in late 67 and in 1968 DOT mandates changed and folding unlocking folding seats went away. Along with small back glass for visibility requirements. Well here are the steps to do this modification to your non folding seats.
First step cut the weld at the junction of the seats.
Step 2. Separate the seats and grind the welds smooth.
Step 3. Reassemble the seats and slide a bolt with a nyloc nut through the pre existing hole. Use Grade 8 hardware to ensure it is the strongest it can be.
Step 4. To ensure the seat will recline to the degree of your liking weld a nut atop the existing hole in the seat back to make it adjustable. The weld two 90 degrees peices to the seat back so the bolt will have a surface to rest against to stop it. Repeat this step on both side so one side doesnt sag or lean.
That it for now and as far as the seat frame goes I had a local race car shop with a pipe bender, bend up the pipes off my measurements then I welded it up. Cost 40 dollars instead of 200-250.
Here are some pics...
truckmanloco is offline   Reply With Quote
Old 10-30-2012, 11:40 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Buddy Buckets all the problems and the fixes.
Wow, what great information. I am in the process of rebuilding a set of Buddy Buckets for my 68 and am wondering what "cab support brackets" are? I am also wondering if I will need the buddy bucket seat rear cab bracket. If so, can someone give the dimensions so that I can build one.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 10-31-2012, 09:38 AM   #3
cericd
cericd's Avatar
Info on the "rear cab bracket" : http://67-72chevytrucks.com/vboard/s...5&postcount=87.
cericd is offline   Reply With Quote
Old 10-31-2012, 02:29 PM   #4
truckmanloco
I personally dont think the cab brackets look good that the reason for the box mod. I dont like the random peice of sharp edges metal hanging down in the middle of the cab.
Old 11-09-2012, 12:15 AM   #5
Hart_Rod
Hart_Rod's Avatar
Nice write up!
Hart_Rod is offline   Reply With Quote
Old 11-09-2012, 12:36 AM   #6
truckmanloco
Originally Posted by Hart_Rod View Post
Nice write up!
Thanks Buddy
Old 08-25-2014, 01:04 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been searching the forums on how to make my own center buddy seat.
I've been finding lots of info on the frame measurements. But I'd think the center buddy seat wouldn't be too hard to make.
66 C20 Service Truck:
Old 08-25-2014, 12:39 PM   #8
Steve Cole
Great write up! When you talk about redrilling the holes for the hold down clamps, to push the seat back, eliminating the need for the cab bracket, do you have a pic of what the seat looks like afterward compared to a normal version? I'm sure it only moves it a couple of inches but how does it look?
Also, do you have a good idea for a Replacement adjustment handle? You know for the drivers slider, the one that always breaks? Thanks for the write up !
Steve Cole is offline   Reply With Quote
Old 08-25-2014, 02:31 PM   #9
tommys72
tommys72's Avatar
He probably wont answer Steve. ..being that his account is suspended
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-25-2014, 02:56 PM   #10
Steve Cole
Yeah thanks, I didn't notice that.
Old 08-25-2014, 02:57 PM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Excellent post! Thank you for sharing your wisdom and experience! Priceless!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
