10-30-2012, 11:45 PM | #1 |
Spare Tire Dilemna
I know lots of us have moved our fuel tanks to underneath rear...where spare tire used to be carried, inconspicuously. What can we do about carrying a spare now? either same as on the ground OR space-saver? I don't like the looks of it thrown into the finished bed like an "Oh my, I almost forgot that!"
How about some kool ideas? |
10-31-2012, 12:54 AM | #2 |
Senior Enthusiast
Re: Spare Tire Dilemna
Since my truck rarely ventures far from home, for several years I just carried a can of Inflataspare in the glove box. I figured if that wouldn’t get me home I’d call AAA. Subsequently we’ve decided to take some longer trips, so I went back to carrying a spare clamped to the right front bed floor with a Camaro bracket and j bolt. Of course in my truck this is hidden under the hard cover.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
10-31-2012, 02:23 AM | #3 |
Dont know but I sure wish I had a sapre tire the other night.... Lol
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
10-31-2012, 08:20 AM | #4 |
Can always go to the fender mounted spare
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-31-2012, 10:30 AM | #5 |
Did the stepsides have the 'In-The-Bed' mount as the fleets did?
http://s1299.photobucket.com/user/jb...23904108567829 |
10-31-2012, 10:52 AM | #6 |
No, that was a fleetside option only as far as I know. I imagine that it'd be possible to install one w/some mods.
10-31-2012, 10:55 AM | #7 |
10-31-2012, 11:16 AM | #8 |
blessed66...what he's refering to is the fleetsides had a spare tire mount that mounted inside the bed, not under.
10-31-2012, 11:18 AM | #9 |
Heres a pic
10-31-2012, 11:23 AM | #10 |
I need /want one of those in the bed spare brackets
Posted via Mobile Device |
10-31-2012, 11:44 AM | #11 |
1937-56 ran this style of spare mount for the in bed design
10-31-2012, 12:33 PM | #12 |
bbadfred
I don't carry a spare. We have AAA road, service bout 100 bucks a year covers all our vehicles. Motorhome,car, three trucks and two motorcycles. all towing, tire replacement, breakdowns and overnite expenses if you are stranded. Also availible from Good Sam rv club, Harley Davidson and others
10-31-2012, 12:59 PM | #13 |
Once the truck is on the road I plan of having AAA as well heard good things about it.
10-31-2012, 01:10 PM | #14 |
Would be easy to install a spare tire tub and the fleetside mount in a stepside.
10-31-2012, 02:06 PM | #15 |
Has anyone adapted one of the later model cable, crank type, under bed carriers for our years of truck?
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
10-31-2012, 02:47 PM | #16 |
Mount Your Spare Tire in the Bed :
If your decide to take your gas tank out of the cab and mount one underneath the bed, you'll have to find somewhere else to put your spare tire. Here's one idea that just might do the trick. It comes from Ryan Miller. This article shows a '67-'72 truck bed but the same thing has been done on the '60-'66 beds. This spare tire carrier will only work in a long-bed Fleetside truck. This was done with a steel floor but can be done with a wood bed as well. The carrier fits a stock 235-75X15 tire or any tire that is under 29" tall. A Fleetside wheel well was located at a local boneyard for $25. The well was cut and welded as shown in the picture to shorten it so it would fit between the tailgate and the wheel well in the truck. If you have access to a wheel well for a wood bed, it can be used so that you have a flange to be able to bolt it into place for those who have wood beds. |
10-31-2012, 06:17 PM | #17 | |
The rear has 3-4" lowering coils in back. Also these rims are used with 1.5" spacers so taking the rear tires off requires two jacks; one under the diff and one under the tow-hitch to slightly raise the body. I may go back to the original 15's and be done with these as that would solve that issue. The hoist unit is a Toyota truck item, late 80's i think. I like the chain instead of the cable because I'd heard stories of cables snappiIg and tires dragging. I got a lot of this from the big RV-ers. They do this modification as well using an electric hoist. The tire is a 235 x 70 x 16. I placed some bumper-spacers to leave space enough for the crank-bar to fit in(for raising and lowering).
MusicMan70 1961 GMC Suburban |
10-31-2012, 06:26 PM | #18 | |
10-31-2012, 06:59 PM | #19 |
Thanks to all & for all the ideas. MusicMan70, I esp. like your 'burb setup--cool recess in that tank to allow the nice chain fall adaptation. Too bad I lucked up on a plain alum. cell at the salvage yard for $20: it is symmetrical w/o a recess
My truck is (was) finished, later model steel bed grafted in and rhino'd, but now looks like I'm gonna have to modify a tad & install an 'inverted wheel tub' in one corner for hauling a spare--thanks, 62 Longbed, for the idea & pic. Prolly gonna use one of those space-savers from the '80's in the process. Last edited by luvbowties; 10-31-2012 at 07:02 PM. Reason: added acknowlgmt. |
10-31-2012, 09:13 PM | #20 |
plenty of 50's-60's chevy cars had bolt in versions in the trunks. be easier than modifying a wheelwell. just cut and bolt in
10-09-2018, 03:09 PM | #21 |
But Found Her 25yrs Later!
Saved for reference
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-09-2018, 07:16 PM | #22 | |
Moderator
