Old 10-31-2012, 12:06 PM   #1
Blue Heeler
Blue Heeler's Avatar
drop spindle selection
Hey guys wanna lower the Blue Heeler 5" front and 6 rear with blocks and notching the frame. i see most spindles they sell are 2 1/2 drop will it be to low? i currently have 3" front and 4" rear if someone has a couple pic's to show it would be helpful. thanks.
Blue Heeler is offline   Reply With Quote
Old 10-31-2012, 02:20 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: drop spindle selection
CPP's modular spindles are a 2" drop versus most which are 2.5".
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-31-2012, 02:39 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Look here to determine if it will be too low,...
http://67-72chevytrucks.com/vboard/s...d.php?t=507575
Keith
Convert to disc brakes.
Old 10-31-2012, 04:21 PM   #4
forestb
forestb's Avatar
the possibility of 5 in the front also depends on what size tires you are running or weather you want to slow down for dips in the road.
forestb is offline   Reply With Quote
Old 10-31-2012, 05:09 PM   #5
Blue Heeler
Called CPP
Sat on the phone for 17 minutes on hold the first time then called the next day another 15 minutes waited a week and after 10 minutes i just hung up. aftr looking in catalog they seem to be price higher than other companys
Old 10-31-2012, 05:11 PM   #6
Blue Heeler
I'm running 15" rallys 275-60-15 rear 245-60-15 front
Old 10-31-2012, 06:24 PM   #7
MisterC
MisterC's Avatar
This page will give you a glimpse of the different ride height. This guys are great to work with and their parts are top notch!
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 10-31-2012, 08:17 PM   #8
Blue Heeler
Here is a picture of my truck now.
Old 11-01-2012, 06:41 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A couple of years ago I built a 63 truck. 3 inch springs and 2.5 inch spindles in the front with the same size tire you're running (245/60-15). This is exactly how yours should sit with that combo.
Old 11-01-2012, 09:20 AM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Did you have to trim the a-arms at all? which spindles did you use?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-01-2012, 09:24 AM   #11
Tx Firefighter
No arm trimming required. The front wheels were 7 inches wide with 3.5 inch backspace. Cleared just fine.
Spindles, I ordered from Summit. I ordered CPP spindles from them because they were the cheapest and Summit had them in stock and none of the CPP typical BS that so many people go through. When I got the spindles and opened the box, they were Western brand castings. CPP sells them under their name.
Old 11-01-2012, 10:27 AM   #12
Blue Heeler
I want a set of spindles that fit my factory stuff with a 2" or 2-1/2 drop. I don't need all the big brake stuff, big calipers and all the crap that goes with it. i'm running 15x8 rallys is there gonna be a clearence problem or am i good?
Old 11-01-2012, 10:48 AM   #13
chevy_mike
chevy_mike's Avatar
Yes, the modular spindles cost more becuase they will allow you to convert to larger brakes if you ever want to. The caliper mount is swapable unlike the cast in styles like Tx Firefigher shows above.
Here's a pic with 15x8, 4.5" BS steel wheels and the clearance between the arm lip and wheel. That extra .5" of other spindles will likely cause clearance issues. Sorry for the blurry pic.
Here's a pic of the modular spindle.
Old 11-01-2012, 11:36 AM   #14
Blue Heeler
So are you saying the 2.5 drop will rub? I can buy the cpp 2" stuff if thats wut i need, i just dont like buying stuff i cant use then having to return it.
Old 11-01-2012, 11:46 AM   #15
HouldenCaulfield
And, you have to convert to disc brakes to run spindles, correct?
HouldenCaulfield is offline   Reply With Quote
Old 11-01-2012, 11:53 AM   #16
Blue Heeler
Yeah i'm putting on disc brakes all 69-70 stuff.
Old 11-01-2012, 12:19 PM   #17
chevy_mike
chevy_mike's Avatar
From a number of posts, it does seem that 15x8" wheels with 4.5" BS will hit the lip of the lower arm with a 2.5" drop. I personally have not tried so I am only relating to what others have found. If you have less BS or a narrower wheel, 2.5" drop will work fine.
I have my '68 with the 2.5" spindles and have a set of 15x8" rallys I want to use but haven't test fitted them. To be safe, I picked up a pair of 15x7" rallys, just in case.
Old 11-01-2012, 12:57 PM   #18
Blue Heeler
Thanks for the input ChevyMike, I just need to know cuz i really would hate to do this twice. some shops that i called just want to sell stuff and that would suck to mount all this and find out that it's not gonna work.
Old 11-01-2012, 01:08 PM   #19
doobiebro
doobiebro's Avatar
Yeah Tex is correct on that...I bought my set up (1960) from CPP and the spindles are from Western... I know for a fact if you are using your OEM rims they will not work!!!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 11-01-2012, 01:26 PM   #20
Calvin66c10
Somewhat irrelevant but what is the diameter on the hub of those 6 lug disc brakes? Looking to clear a rim with a 3" center hole. thanks
Calvin66c10 is offline   Reply With Quote
Old 11-01-2012, 01:29 PM   #21
Pro Performance
Pro Performance's Avatar
As for the CPP Modular spindle, keep in mind you also have to buy the bracket to adapt your stock brakes to them.
Pro Performance is offline   Reply With Quote
Old 11-01-2012, 01:42 PM   #22
Blue Heeler
Man what a joke!!! if the 2 1/2 will work then i will buy them. just trying to finish this stage and move on to changing out manual trans to auto trans.
Old 11-01-2012, 02:22 PM   #23
Clyde65
Clyde65's Avatar
OK, so im confused ( no real shock there)
I have 71/72 discs now, I have 15*8 rallyes. do I go with the 2", the 2.5" or the modular spindles? I do not want to mess up my a-arms or my rallyes.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-01-2012, 02:27 PM   #24
Pro Performance
From the look of the picture above, you will want to go with a 2" spindle, cause the 2.5" will put the a-arm right against the wheel.
Old 11-01-2012, 03:34 PM   #25
Blue Heeler
well for what it's worth just got off the phone with CPP and they did say 2 1/2 drop spindle will work with an after market wheel but not with stock rim. i grinded the guy for atleast 15 minutes on this and he assured me there is no problem part#CP4S2 thats using you stock stuff tie-rod ends 68-70 rotors and stock calipers.
